yung bad smell... air cleaner needs replacement or bad a/f mix(rich).
white smoke(valve seals,piston ring), bad a/f mix... engine needs attention.
with regard sa taxi na hindi na ginagamit ang gasoline... ganun na din sa taxi namin. 1 reason would be kasi hindi kaya ng solenoid i-hold back yung gasoline from getting into the carb. kaya ayun, naghahalo minsan gas ang LPG. result.. not good. hindi maganda ang hatak and malakas siya sa LPG. this is my experience with the carb kit tsaka yung carb kit na may circuit para sa efi(which we use for the series 3 sentra). sa taxi kasi important na matipid sa LPG yung taxi mo or the driver leaves you. medyo maselan na kasi taxi drivers ngayon regarding LPG consumption unlike before nung una lumabas ang LPG kits.
work needs to be done with the switching(gas to LPG and vice versa) system.
im not too sure about the "reduce cost" reason.
one other thing is, wala nang driver samin na gumagamit ng gas anyways so i didnt bother contemplating for an improvised system for a better switching system.
