ssalongga: btw, with regards to the blend of synthetic oil you were talking about, how much price difference am i looking at if i were to use a toyota motor oil at P110/L at toyocars in banawe? i seriously am considering this one. our units are all 2nd hand taxis. no bnew units.
Dencio, mahal pala yun! Just called up my friend -- its 1,000 per liter daw, altho they are out of stock at the moment waiting for the Oberon additive. Sorry, binibigyan lang nya ako every now and then. They mix them by the drum and the "butal" is collected, yun ang binibigay nya sa akin! He says the brand new cabs have been using it for 2 years na at marami naman day bumibili. Sold by Caliber Trading in San Juan, a guy named Danny Aquino. FYI nalang!
the real value of the "feedback" system is that the A/F ratio can be adjusted two or three times a second by the "ECU" which takes its readings from the O2 sensor, the ignition timing from the distributor and the vacuum reading from the manifold (below the throttle plate) and determines the correct mixture from a stoichometric map or graph in the flash memory of the ECU. I believe all the Italian's have them but I havent been able to get any direct info from Macro!
cheers!
