-- mas mahina daw hatak when going uphill. dati rati daw, with 3-4 people onboard, with aircon on, no problems daw. ngayong naka LPG, di na daw kinayanan even without aircon
Improperly tuned system (too lean or too rich) will result in low power. The problem with NAIADSS is they do not have any equiptment to properly tune the LPG kit. I have adjusted my LPG kit to give more power.. still not the same as gasoline but more than enough power to go uphills with A/C on and four people in the car.
-- kelangan daw ng "special" sparkplugs pag LPG kit. ung 'ordinary' denso sparkplugs, mga isang linggo lang daw tinatagal; nasisira daw dahil mas mainit daw pag LPG. ung kelangan daw gamitin is some sort of sparkplug that has four prongs/produces four sparks
sounds like lean burning engine here...
-- most alarming of all...kelangan daw mag mini top overhaul every so often. me namumuo daw na layer of soot on the cylinder heads, which needs to be cleaned out regularly(parang months ata ang pagitan?)
??? ... engine running too rich part of the time? I have that problem at the moment, I can't seem to properly tune the idle a/f ratio, still running rich at idle.
-- finally, and strangest of all, mas madali daw nanunuyo ung lalamunan niya when he started driving an LPG converted unit. i'm not really sure what to think
he might be becoming diabetic... maybe.
