Results 1 to 20 of 4201
    Sep 2009
    Good day Ryan,
    I am also new to TSIKOT. I am interested in converting my car. How much is the charge for a 1997 Mazda 323 carburetor type?
    Kindly send me a text message 0917XXXXXXX.
    Lawrence
    Quote Originally Posted by theveed View Post
    eto yung message:
    "Hi guys!
    I am new in this forum. I hope to meet with you sa mga ebs and other gatherings.
    Our company, NAIADSS Corp. is currently looking for those interested to convert their cars to bi-fuel engines (gasoline & LPG). So this is great news for all of you who are looking for alternative means of savings lalo na with the rising cost of gasoline.
    For your info, you may view the following sites for your reference :
    FAQ on AutoGas by Shell
    http://www.shell.com/home/Framework?...aq_031203.html
    We are willing to convert for FREE any 1300 Corolla model from year 2000-2005. The only requirements are:
    (a) Car must be in good condition.
    (b) Owner must be willing to display his car * the PICC on Oct. 26, 27 &28 for our marketing event.
    For questions and inquiries, you may contact me at 0922-8063210 or email at rkangeles*yahoo.com
    Thanks and see you soon!
    Ryan
    _________________
    Ryan Angeles
    Auto-Lpg Consultat
    0922-8063210
    rkangeles*yahoo.com
    _________________
    Ryan Angeles
    Auto-Lpg Consultat
    0922-8063210
    rkangeles*yahoo.com"
    Quote Originally Posted by gakungman View Post
    Good day Ryan,
    Lawrence
    Kindly check the list of Auto-LPG installers in the link below:
    http://tsikot.yehey.com/forums/showthread.php?t=50159
    Ask for a "venturi" kit.
    Dec 2007
    Any refill stations in Angles?
    Parang wala. The places outside of MM that i know is Baguio and Cebu.
    just came back from GF dahil ayaw na mag idle yung kotse ko laging namamatay. 2nd time nangyari ito, the first time pinalitan ng reconditioned vaporizer kasi sabi nila may mga metal parts inside the vaporizer which bends overs time, end result no idle control.
    based sa info from GF palagi most of the clients who go back with this kind of problems are mostly honda (civic,crv etc) dahil mas mainit daw ang working temp ng honda compared to other cars which i find weird.
    now my ride is working again with lpg kaso over period of time mukang ganito na naman ang mangyayari...mukang hinde reliable ang kit na kinabit ng GF sa mga kotse natin ang mahal pa naman ipa repair pag out of warranty na ang kit mo..not good.
    tanong ko lang sa mga other tsikot lpg users, na experience niyo na rin bang palitan yung vaporizer niyo dahil sa ganitong problema?
    So far the problems with the Greenfuel SGI kits we have are the injectors needing cleaning like the Honda City 1.3L iDSi.
    The 2nd gen Honda CRV 2.0L runs well enough after the "sinok" problem was figured out. The 2002 Toyota Camry 2.0L runs smoothly. The 2008 Nissan Sentra 1.3L runs well but had to go back once or twice for injector cleaning.
    My 1999 Corolla 1.6L (NAIADSS) venturi with emulator kit is running well. No maintenance done since the new filler was installed.
    thanks for the info. bakit kaya ganun yung vaporizer na naka install sa kotse ko? second time na ito nangyari eh hinde ko naman ginagalaw yung adjustmet ng idle screw pagtapos nila i tune up.
    kung sinasabi nila na dahil daw sa init kaya nagbebend yung metal parts dapat nakikita ko na rin na abnormal ang temp ng kotse ko eh normal din naman.
    Aug 2006
    Quote Originally Posted by n5110 View Post
    Over a year na rin ang kit ko from GreenFuel so far no problem, been using my car 80Kms minimum daily and so far no problem encountered. Average 7.5-8.5km/li on LPG on my 2.0 VVTi engine with daily refill of 9-11 liters daily.
    Nagkaproblema lang ako during the early install ng kit, na correct lang ang problem ko na erratic idling ng palitan yung coil ko ng tinatawag nilang BFC injectors (big coil) eto daw yung match sa 2.0 engines.
    And no more oily LPG contamination ever since I do all my refills at Total North Fairview only.
    Nagkaproblema din ako sa fuel gauge at pinalitan din nila.
    For me, no problems whatsoever with the Greenfuel SGI kit installed on my 2002 Camry 2.2L A/T. I used to manually switch to LPG after a couple of minutes everytime I start the engine and manually switch back to gasoline before shutting the engine off. This was the crude workaround I was using to prevent that mysterious and intermitent engine stalls at times when auto-switching from petrol to LPG.
    Went to Greenfuel >2 months ago to have it checked and if I'm not mistaken, they just made some adjustments with the vaporizer screw. Since then, my LPG has been flawless...(touch-wood)
    Cheers!
    matagal na ganito ang naging prob ko, hirap ang idle ko and hard starting talaga, then brought it back to GF then pinalitan nila yung manual valve sa intake ng lpg, yung screw type na blue plastic valve, di naman halos nagbago ang pag start, kaylangan lang na normal operating temp na (half nung temp guage) before i switch to lpg, otherwise, hirap ang idle ko til mag stall, worse is yung may parang uutot sa system na parang makaclog na at ayaw na mag start totally sa lpg. to be continued sa reply sa baba . . .
    Quote Originally Posted by scian_ph View Post
    The Solenoid Valve (SV) is at Normally Close (NC) position, meaning without electrical charge it is at close position. The SV is working at 7.5 A and 12V DC supply. If you switch on LPG mode then your hear a "TICK" sound, that indicates that the SV is at open position. If you try your VOM on your battery prior to your test in SV supply voltage then their is something wrong with the electrical system.
    Second, if the electrical system is fine, then the tip of the Valve that close/open the flow is not already uniformly flat due to wear and tear. So, in that point even at close position there is still a flow of petrol supply.
    Third, this two factors can occur at the same time.
    May I know what brand of Auto LPG Kit you are using?
    my ride is lancer 2000 glx, carb type ito, and wala na ko mixer, straight na sa carb ko yung intake ng lpg, meron lang nilagay na air restrictor, para ni-choke para tama ang timpla sa lpg, anyways, after bringing it back sa GF, yung solenoid nga for petrol, nag stuck na daw yung piston, i dont know if sa normal use ko or dahil din sa e10, anyways, nung binalik na yung SV, check din yung vaporizer, then nakita din na may sira dahil no flow control na din sya, so ganun din at palit ng recondition, now lahat solve na, no more hard starting, at maganda ang takbo ko.
    only gripe is that, nung first time na punta ko, when i complained bout sa hard starting (while still in warranty), di check yung vaporizer, when yun lang pala ang prob ko, and solved months later when i go back for other problem and no more warranty.
    sa mga nakapag palit na ng parts which is out of warranty na, pwede ba natin i compare ang prices dito? (not sure if allowed ito, pero just to give an idea how much ang expected gastos natin pag may nasira.)
    Solenoid valve (Petrol) 1K (discounted from 1.5K)
    Quote Originally Posted by quan2boy View Post
    Cheers!
    Tanda niyo pa ba kung anung tatak ng vaporizer na naka install sa kotse niyo?
    To those who don't use synth oils for their LPG rides, i was at ACE Hardware yesterday and i saw they have mineral Mobil Oil (15W-40) labeled for use with LPG engines.
    na try niyo na ba? magkano per liter? im using top1 synthetic oil, dahil matanda na rin yung oto ko.
    Quote Originally Posted by kapitan88 View Post
    kadalasan i wait for the engine temp to go normal (1/2 gauge) before switching to lpg para smooth ang takbo when lpg is use.
    about sa vaporiser repair 1.5k ang charge ng GF. nakita ko na kung pano nila binaklas. hinde naman ganun kahirap i balik kaya next time ako na siguro ang gagawa nito.
    ito nga lang ang problema pag may sira ang lpg natin, walang available na parts sa ordinary car parts shops.
    Its around P 800+ per gallon.
    Jan 2010
    *GhostHunter
    thanks for posting the lpg refillers and lpg installers.you're a big help to a newbie like me.thanks again sir.
    long time no post hehehe
    sir GH, ask ko lang, how much woud it cost kung iswa swap ko yung current tank ko into toroidal? kahit rough estimate lang...
    eto yung itsura nung current tank
    Quote Originally Posted by ezem View Post
    http://i179.photobucket.com/albums/w...S/DSC05488.jpg
    No idea on the actual cost, but you might be looking at P6000 for the new toroidal plus new copper lines for the filler & vaporizer lines.
    I am assuming you are planning to place the toroidal tank under the Adventure?
    yup...kasi kung within the metro lang ang dra drive-in, excess baggage lang yung spare tire since pag nabutasan ka, maitatakbo mo pa yung auto sa vulcanizing naman, and nasasayangan kasi ako sa space na kinakain ng tank sa likod e hehehe...ilalagay na lang yung spare tire sa likod if ever maga out of town.
    thanks sir GH...atleast may idea na ako kung sa magkano maglalaro yung price...
    good day,
    Im driving a cefiro with v6, just want to know what kit best suit this type of engine. thanks
Auto-LPG Conversion Thread
