Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 127
  1. #101
    if for everyday world, i dont have plans of racing it....pero siyempre minsan ayaw mo naman mapahiya sa traffic light drag...
    4age 20v silver or blacktop vs. b16a/b18c vs MIVEC 4g92/6a10/6a11.
    OT na kasi pag sinama ko na mga T na sikat sa pinas...sr20det,4g63t. i just want a n/a alternative na din...so dyan nalang sa mga engines tayo iikot at mag-cocompare...
    mazda, walang vvt pag same year, right? T lang din: b6T, BPT...
    Aug 2004
    #102
    The only Mazda high-powered NA engine that's available is the FSZE. That's non-VVT, but it's VICS equipped. It's a 170 hp 2.0 engine, with peak power at a heady 7000 rpm (higher than the FSDE in the Lynx RS can even rev).
    Nearly impossible to swap here, unless you have a Ford Lynx RS and a mechanic familiar with the FSZE.
    The VQ20 isn't a screamer, but it's over 160 hp, right? It should be possible to do a Sentra swap , as they've already swapped the VQ30 into the Sentra in the US (yeah, you heard right... a 225 hp V6 in a Sentra... and yes, it goes like stink)... but then, it's a very, very difficult swap.
  3. #103
    vq20 sa maxima ko ilalagay, swak kaya? un talaga option ko until, mom decided....pero still kung macoconvince ko mom ko, tutuloy ko project na ito.... cefiro swapped auster/maxima....tsaka na ung TT upgrade...
    masyadong mahal kasi pag new motor,e....now kung makakakita ako ng manual cefiro donor, kahit hindi registered, ok na yun....
    open pa rin ako sa choice ko 2-3 nalang....hindi lang kasi HP habol ko, mas particular ako sa torque, pero mas gusto ko NA...
    Aug 2004
    #104
    As always, ang problem mo lang talaga ay wiring, at kung may electrician ka na familiar sa pin-out ng engine.
    But if it's the old CA20-equipped Maxima, an SR20DE or SR20DET swap is easily doable, and you won't even have to bother with shaved axles (the downfall of many SR20 swappers who are too cheap to buy original US axles for their Sentras), as the Altima axles will probably be exactly the right lengths.
    After that, good body work, mags and seats... meron ka nang classic cruiser...
  5. #105
    yup ca20 ako... and it consumes like a v6, but only puts out like modern 1.8L..
    di ko gagayahin yung nag sr20det swap na may body kits.. kung gagawin ko to stock look, dadagdag lang ako ng chins....and remove the spoiler.... is it safe to replace my undercarriage (suspension systems,etc..magagamit ko lang is ung body and interior), lets say for a series 3 sentra/cefiro?
    iipon pa me konti pa...while that: tuloy pa natin discussion dito, baka makita ko kung alin mas feasible:
    ang newer modified car kaysa sa old school-car, revived!
    Aug 2004
    #106
    Well, the nice thing about the CA20 is that the Maxima can still hit 200. Too bad you'll never find a road long enough to do that...
    Maraming "sleeper" na Cefiro na naka RB26DETT... marami ding "sleeper" na Sentra/California (boxtype, kapanahon ng Maxima) na naka-SR20. It's a good way to go... keep the body clean, spend a little on the cosmetics.
    The undercarriage, I honestly don't know, because I'm not familiar with the platform. But if you replace everything with new parts, it should stiffen up. If you're Obsessive Compulsive, you could also re-weld all the joints. That stiffens up the body and improves handling. I've seen DMF Motorsports do it to old Corollas to prepare them for drifting... kaya lang, sobrang matrabaho.
  7. #107
    matrabaho talaga, ung gagawa ang problema.... parts walang problem, buong series3 or buong cefiro lang ok na....sr20det madali nalang din yun...pero, coconvince ko muna si mami...kungdi corolla or civic, sentra or 323 familia(better kung 323F) or lynx ghia...
    balik tayo sa VVT topic....
  8. #108
    ^ kindly identify this MIVEC engine..di siya familiar,e....
    #109
    Quote Originally Posted by alwayz_yummy View Post
    What model is the car in the pic?
  10. #110
    transpalanted to a lancer-itlog based car: wira
    #111
    It's a 4g92 based on the claim of the owner of the engine hp rating. The only other 16 valve MIVEC engines for MMC was the 2.4L 4g69 on the Outlander and the 4g63 turbo on the Evo IX. The 4g69 was a recent addition to their engine line and the 4g63 didn't have MIVEC until 2006.
  12. #112
    DOHC? alam ko kasi SOHC lang MIVEC 4g92...and di ko basta basta naniniwala,e.... ung mga wira nga dun, mahirap paniwalaang wira lang sila....
    #113
    There are 3 version of the 4g92 engine, the SOHC, DOHC non-MIVEC and the DOHC MIVEC.
    4G92 16-valve SOHC 1.6 liter MPI specs.
    Displacement: 1597cc
    Compression Ratio: 10.0:1
    Max Power: 83kW * 6000rpm (redline 6500rpm - limiter 6750rpm)
    Max Torque: 137Nm * 5000rpm
    4G92 16-valve DOHC 1.6 liter MIVEC specs.
    Bore x Stroke: 81.0 x 77.5Piston
    Compression Ratio: 11.0:1ECI-Multi(Electronically Controlled Multi-point Fuel Injection)
    Horsepower: 175hp/177.4PS/130.5kw *7500rpm
    Torque: 123lbft/167Nm/17kgm *7000rpm
  14. #114
    sprinting engine din pala yan...just like 4age20v and dohc vtecs..
    ok na...may 92 din pala non-MIVEC....bago lang ba engines na ganyan?
    in short, kailang production years nyang engine nayan?
    #115
    SOHC is non-MIVEC.
    Non-MIVEC DOHC was available on the Lancer MR 92-93. I don't know what that translates to in the RP.
    DOHC MIVEC was available on the 92-99 3 door Lancer/Mirage Cyborg R/ZR (hatch version of the Lancer itlog and pizza)and the Mirage ZR/Asti RX(same body as the Lancer GSR).
    The production dates may differ, AFAIK the MIVEC was only offered in RHD cars, but I could be wrong. The non-MIVEC DOHC was still being used in the pizza AFAIK in LHD cars. The US just got the 4g15 and the 4g93 for the pizza and the itlog was the last time we saw the 4g92 just not sure if it was SOHC or DOHC non-MIVEC.
  16. #116
    thanx po...hehe...tignan ko sa surplusan dito baka meron....hehe....atleast alam ko na itsura... 6a10 MIVEC nalang...
    #117
    I wish I could get the 6a10 MIVEC so I can put it in my GSR like the guy in the RP I saw in cardomain with a V6 in his GSR. Anybody know who that guy is? For now I can only swap to a 4g93 or change my 4g15 to a DOHC(still not sure if this LHD cars). What kind of car do you have?
    #118
    Just to put the 4g92 MIVEC in perspective here is a list of some of the highest horsepower per liter N/A engines and cars.
    Ferrari F50 GT = 153 per liter
    Honda F20C = 120
    Honda B16B = 116
    Ferrari 430 = 112
    Ferrari 360 = 111
    Honda B18C = 111
    Ferrari F50 = 109.4
    Mitsu 4g92MIVEC= 109.375
    Ferrari 355 = 108.57
    Ferrari Enzo = 108.33
    Toyota 4A-GE = 103
    Ferrari 599GTB = 102
    Just imagine if it had the same displacement as some of those Ferrari engines.
  19. #119
    sabi sa kabilang forum MIVEC-MD:modular displacement early models daw ng engines na nagpapatay ng 2 cylinders....v6 nagiging v4...may ganun din ba?
    #120
    Check www.mivec.co.nz for more info about MIVEC.
variable valve engine comparo
