Results 31 to 32 of 32
February 25th, 2006 11:46 PM #31
i think it's better that you list down the major things you want to have in your car, then rate them one by one, it's easier to determine something in terms of numerical value right? the choice with the highest rating of course is the one you will choose...
for example, which feature in a car is most important to you... looks, power, fuel economy, safety, comfort & convenience, stability, craftmanship, etc... then give equivalent weight percentage to each of them, adding them up should be equal to 100%, then rate the 2 cars according to the features you had defined with values from 0 to 100 (0 being the lowest and 100 being the highest), multiply each with the equivalent weight percentage, then add them up! whichever got the highest point is the car you will choose!
- Aug 2003
- 114
February 28th, 2006 04:28 PM #32Originally Posted by kpdlr
If you've got 1.4 something million, the RAV4 4x2 is for you. Be aware though that its still overpriced.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
