Results 31 to 40 of 75
March 21st, 2024 07:05 PM #31
The 5 is no longer a Jimny to me either.[emoji4]
Sent from my SM-S901E using Tsikot Forums mobile app
- Mar 2024
- 6
- 54,205
March 31st, 2024 09:53 AM #33... gas?
if older model (probably cheaper, too),
gasoline revo or gasoline adventure.
at least, these will probably still have more spare parts around, than the others.
if newer (more expensive model),
any of the current gasoline-powered vehicles with a higher ground clearance and ride height.
so many to choose from...
good luck.Last edited by dr. d; March 31st, 2024 at 09:59 AM.
March 31st, 2024 10:28 AM #34
Ford Expedition (first generation)
Way under 300k, very high ground clearance, reliable if maintained, and absolutely drinks fuel like nothing else in this day and age
March 31st, 2024 12:33 PM #35
May clear puddles but will break one to keep it running. Very Ford-typical.
March 31st, 2024 06:42 PM #36
Its actually reliable but most +20 year old examples are probably in poor condition by now. Newer Fords from 2010 and above are less reliable and more complicated.
We had one and it reached 200k kms over 15 years with very few failures, mostly just the AC and suspension. The rest are maintenance items like oil changes, plugs, etc. I used it in college where it occasionally floods and the brakes got stuck once
March 31st, 2024 08:26 PM #37
You must've cared well for it. I had buddies who gave up on em early to skirt the suspension fixes. They got clunky way earlier than their nippon contemporaries.
March 31st, 2024 10:26 PM #38
Maybe the gen 2 avanza ? according to daihatsu it has 500mm wading depth and ecu placement height of 800mm high. it probably has decent parts support as well.
Avanza vs Ertiga (video link and wading depth)
Tsikot Member Rank 3
- Nov 2002
- 1,982
April 1st, 2024 01:20 PM #40I had a J-top Pajero (gas) before and used it going to the flood prone school in Manila.
You can look for older model Pajeros, Fieldmaster variant if kaya or old nissan patrols, or 1st gen Toyota Gas Fortuner.
Alternatively a second hand Older model Suzuki Jimny has proven its worth according to a relative. its good for floods but sirain daw suspension.
another car that i have tested sa flood is the old Mitsubishi Strada Pick-up.
Yeah decorative bollard. A proper one is supposed to stop even a heavy truck. Apparently the ones...
