Results 81 to 90 of 126
- Jul 2016
- 939
June 2nd, 2017 04:08 PM #81Sir, ung sa video link nag start mag accel si civic around 3ish second mark sakto at 11sec. Sa video na reach na nya 100kph so nasa 7ish sec nga po 0-100kph nya. Hehe..
Obd2 torque app super inaccurate as you would suggest.
For your info, bone stock b16b and b18c type r engines na dyno namin at 160whp using dynapack. Gt86/brz, 160whp rin. Miata nasa 120whp. New civic 1.5T nasa 170whp..
Give or take 3 - 5whp na lang...
June 5th, 2017 04:50 PM #82
Haven't done the 1.8. The FD 1.8 was in the 10 second range. The ES was much slower. Around 11. The new one isn't much lighter than the ES, so I expect it to do mid-10s to 11.
Current crop of PPVs, TBZ is still in the 9-second range (from COTY), Fort 2.8 is in the 11-second range, Eve is slow, about 12+ even with the 3.2, Isuzu in the 11s, Monty, I don't recall... but maybe high 10s.
Hahahahaha!
The only time I ever VBoxed an EK SiR it was around 7.6 in real world conditions. Full IHE, but, realistically, that wouldn't have made more than a 0.2 second difference.
But that's with sticky tires and a good drag launch. In real world non-clutch shredding use, a Focus TDCi can match an SiR, and that's a mid-8 second car.
I did my 7.6 on a hot runway with the car heat-soaked. Yes, ambient heat will affect it, as the second run was around 7.7 to 7.8 seconds, and the 400 meter time dropped by 0.3 - 0.4 seconds (so I didn't do a third pass).
Also, the economy is legit. The CVT DOES have a torque converter, but Honda's clutch packs lock up very early, so you're not wasting energy accelerating the car. I've seen low 20s from the Civic in short cruises.
You're on. Magkano pusta? As long as the car squeaks under 8 seconds, I'd consider that a win for me.
Racelogic V-Box Sport. 20 Hertz accuracy (accurate to 1/20th of a second). Coupled to RaceChrono, gives accurate acceleration and deceleration curves, as well as lateral and longitudinal g-force readouts. Granted, it's not as impressive as the $10k V-Boxes Car and Driver uses, but it's twenty times more accurate than a cellphone or a "scan tool"......which is why we use it. OBD scanners run off the car's own internal speed sensors, which are usually 5-10% off. No self-respecting tester would rely on those for speed tests.
If you want instant, unfiltered readouts, I've also got a regular Racelogic V-Box. Just 10 Hertz resolution (1/10th second accurate), but doing multiple trials should sort that out.
I've got a nice patch of private road to do this on. It's only 200 meters, but that's more than enough for a car this fast.
Alas, carry on trolling like you're doing now, and you'll be banned before we get to do that test.Last edited by niky; June 5th, 2017 at 04:54 PM.
June 5th, 2017 05:01 PM #83
You mean the FB? Have one now, the 1.8 EXi. It's still faster than any 1.6 AT compact says my butt dyno. Almost as fast as my old Altis 1.6 MT, just that the MT had better ratios.
Feels like a 10-point-something 0-100 car. The FC looks more promising because the CVT seems better when it comes to acceleration because of the infinite gearing and perpetual powerband when floored.
Weight seems about equal for all 3 generations:
FD - 1235 kg
FB - 1255 kg
FC - 1239 kg
I wish he were trolling but I think he honestly believes all the crap he's effusing.
Sent from my SM-N9208 using TapatalkLast edited by jut703; June 5th, 2017 at 05:38 PM.
June 5th, 2017 05:05 PM #84
Where is this private road? Is it a public road or a subdivision street?
In the Southland road in Las Pinas, the road is long and straight enough for a spirited sprint as long as it is free of motorists, motorcycles, and tricycles. You can hit triple digits when traffic conditions are light.
June 5th, 2017 05:08 PM #85
OT: I can't believe the Isuzu is doing 11s.
To be honest, I felt that the Fort 2.8 was faster than the Isuzu. And the gearing of 1st and 2nd of the Isuzu is "bitin" for me compared to the Fort's as i need to rev the Isuzu at higher rpm to match the acceleration even sa Fort 2.4 (according to my butt-dyno).
June 6th, 2017 10:00 AM #86
June 7th, 2017 04:39 PM #87
High 11s. Possibly 12. I'd have to check my notes.
Yes, the Fort 2.8 is still faster/more powerful.
Yeah... FB nga.
The problem with the FB generation is transmission tuning. Weird off-idle delay in throttle and transmission response. The FD felt much much sprightlier despite the minimal weight difference.
Many Honda products of the past few years are slower in the 0-100 than the roll-on performance would suggest, thanks to this delay. Disappointing, especially with the V6 Accord, which has a fantastic motor-tranny combo otherwise.
The CVT should indeed make the FC 1.8 much quicker. Still soft off the line, but the infinite ratios make up for it. Can't wait to test one.
June 12th, 2017 07:29 AM #88
June 12th, 2017 11:01 AM #89
Big difference in the FB with Econ On and Off. Econ On shifts very early, and needs to be floored before downshifting. DBW delay is also longer. With Econ Off, downshifts come with just a prod.
But even with Econ Off, the FD was still more rev-happy. That said, the FB has very good in-gear performance and definitely felt torquier in low revs compared to the FD, possibly in exchange for top-end push.
You never got to time my old MT Altis, maybe we can give my Civic 1.8 CVT a shot. 😉
June 13th, 2017 12:46 PM #90
Did turn ECON off. It's really the rev-happiness that suffered. Most likely the 1.8 is starting to suffer from stricter emissions guidelines. Probably time for it to be supplanted by a newer motor based on the new L-series in the Turbo.
0-100 km/h, or 0-62 mph, takes about half a second longer than a 0-60 mph run, depending on the vehicle.
There's also the question of 10 foot rollout SAE corrections (which I don't do, because they're ridiculous) and weather. Our hot weather saps power from engines, typically.
I don't know, really, what it was with Hondas of the past few years, but that delay is something I could never dial out, even by deactivating traction control.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
