Results 11 to 17 of 17
- Oct 2008
- 944
August 23rd, 2011 01:49 PM #11*niky
meron kasi nirereto sa friend ko na EK which is only at the same price range of the current EGs ngayon, that's his dillema too. i dunno what's his source nor which engine (EK or EG) was more efficient pero yun yung isa niyang inopen up sakin which makes things, sabi niya, more interesting for him. is that still a hard decision to make?
August 23rd, 2011 02:49 PM #12
Get which ever is cheaper between the EK or EG hatch. Then use the extra money for body repairs and a fresh paint job. HTH
August 23rd, 2011 04:04 PM #13
Ang tanong: Papers?
That's always the most important thing. Papers, papers, papers.
Next is the quality of the steering swap, but that can be dealt with later on.
I know someone who was on the point of murdering a seller because a year after he bought his Type R, he found out the papers weren't in order.
At this point, it's safer buying an import that's been in the country for many years than one just off the boat, but you have to be very certain that the paperwork is in order.
And then you'll have to check the quality of the swap:
1. Did they swap in local headlights or adjust them? Check the beam pattern against the wall. The rightmost side of the light pattern should be higher, not the left.
2. Are the mirrors correct?
3. Did they use an original left-hand drive dashboard? Look for telltale seams or disjointed surfaces to find out.
4. Did they swap over a complete steering assembly? If the wheel turns further to one side than the other, then the answer is likely no.
If the answer to questions 1 and 2 are "no", then consider the cost of fixing, but don't let it deter you. If the answer to 3 and 4 are "no", just go and get an EG in similar or better condition.
- Apr 2008
- 6,235
August 23rd, 2011 05:40 PM #14I'd get the EK that is assuming that there is nothing wrong with the conversion and papers. It is newer than the EG after all and its got more stuff inside unlike the local EG with a puny 1.2L engine and a very barebones interior. If the EK you found does not comply with niky's requirements I would suggest you go for an SiR instead. Same B16 engine, same chassis plus 4 door sedan practicality.
- Aug 2009
- 59
- Oct 2008
- 944
August 24th, 2011 03:10 PM #16*bodz
it will, due to age.
*gti
we're avoiding the engine lalo na yung b16 na yan, he's not into racing din kasi. so if EGs lang ang merong 1.2 na makina, i guess the EGs are more efficient than the EK. sana tama hinala namin. ph12 ang inaalam nila ngayon hehe
*niky
noted na. salamat
*all
salamat!
- Aug 2011
- 6
September 7th, 2011 11:54 AM #17if papers are complete and the conversion is done properly i'll go for EK since it is much newer than eg and it has power steering(for daily driving comfort). but if power steering is not an issue to you then go for the eg.
Mayor Cayetano expressed that she is willing to cooperate naman daw (probably meaning she wants...
Makati Subway. Completion date: 2025
