paayos nyo suspension ng Santa Fe nyo, preferably the lower ball joint, papalitan nyo na, that improved my FC. but of course I also changed the tie rod , rack end, stab links, stab bushings, and new tires hihi. avg FC is 9.5Km-10Km/liter
with the MUX bluepower, I observed that malakas sya pag ang PSI is 35 or less, make it 40 PSI, mali yun rating dyan sa sticker na sa door ng mUX.
basta ang tires nasa 44 PSI max, make it 40, minus 10% lagi.
even my gas guzzling explorer V6 improved at 6km/liter nun ginawa ko 40 psi. but of course, bago palit din lahat tie rod, rack end ball joint and new tires
Chill driving pa yan bro haha. Stop and go traffic is a factor. Q.ave rin is one of my route impossible mag stay sa 40 to 60 kph especially sa mga uturn slots and mga puv and pub na bigla nalang nag sweswerve to pick or drop passenger. Mas efficient talaga sa edsa kahit sabihin nilang sa EDSA LANG MAY FOREVER haha
Sent from my SM-A700FD using Tapatalk
legacy or old school diesel may in fact be economical to modern common rails in some instances. may iba nagsasabi ng ganito. all you need is a single squirt of a few milligrams of diesel fuel for an old school diesel and compression. whereas, modern ECU controlled diesel engines may inject fuel in atomized form up to 7 times (typical) and then compression depending on the injection scheme. in multi injection, though also designed for fuel efficiency, it will have to satisfy other factors like reducing engine vibration, emission standards etc,. these take part of the fuel injected spent somewhere. consider this example, i have two bongos for utility use, both are same size, same engine almost identical. one is old school fired by an ordinary fuel pump the other is ecu driven. and my drivers would attest that the old school is a bit more economical under the same load conditions. okay, the old school is noisy and a little smoky in contrast to the ecu driven. i thought maybe their right foot should have the same behaviour then.
Plausible pero in some cases siguro but in general ECU controlled engines are precise and efficient compare sa non-ECU counterparts nila, hence walang waste ng fuel. The injection is monitored real time once the data or signals from the sensor are sent to the ECU. I work onboard ships, and ang mga main engines of the newer vessels that comes out from the shipyard now adays na ECU and VIT controlled are more efficient and has better consumption. Can run on low rpm without without any problems to the injectors when using bunker fuels on low load not to mention camless na din ang mga bagong main engines ng barko ngayun similar to what the Koenigsegg's sports/hyper car is using on their engines.
Main reason is emission control. If there are no emission regulations then the old banger won't be replaced by CRDi.
Oldies are plain & simple, no much electronics and sensors, does not need to operate at higher pressures. At higher pressures components operate at very tight tolerances and are prone to failure. At higher emission controls, you put up many technologies to lower it thus all emission control device is a great enemy of the engine when it comes to maintenance. If they break, they cause chain of reaction up to the point of engine grenades itself. Over time, imperfections of any newer engines are fixed.
IMHO, the old school diesel is oftentimes more economical than the modern diesel because it is simply incapable of pumping fuel any faster due to the low pressure injection pump. So no matter how much I flog my Revo diesel, it can only accelerate as fast, and therefore only consume at a rate of 7km/L at the worst case scenario.
My Santa Fe CRDi on the other hand, has around twice the horsepower and torque as the Revo and to achieve that utilizes a more modern high pressure pump which enables it to pump in fuel at a faster rate as my irresponsible right foot demands more speed out of it. [emoji28] Therefore gas mileage once went as low as 4.6km/L. A route change and a much, MUCH lighter foot later, that was reversed to 6.4km/L. I am still in the process of discovering whether I would be able to replicate the Revo's gas mileage if I drive as lethargically as I do in the Revo...
Sent from my SM-G900I using Tapatalk
try a piggyback chip to raise the rail pressure even more. newer models have active hardware with algorithm programmed into it. some claimed it does improves drivability and fuel economy in city driving. but a remap will surely do wonders if done properly to optimize for economy (and may sacrifice performance). performance = fuel and more performance = more fuel ... and larger turbos
The Revo was given to another family member who is in need. Hence the buying of the Santa Fe. I do kind of miss the 7-8km/L city consumption. Do tell, is there any modern CRDi that achieves that as a worst case scenario fuel consumption? [emoji23]
I really do hope the Santa Fe makes up for it in good highway gas mileage. I have been too busy to take it for a proper long distance trip since buying it...
It does have, already! I've installed the Unichip from Speedlab which improved power to 145whp and 266lbft. I have also done the Revive treatment from Central Diesel. While the significant performance improvement is definitely welcome, there was no significant difference in fuel consumption... [emoji853]
