Page 1 of 2 12 LastLast
Results 1 to 10 of 1594
    Jul 2013
    Paki explain, hindi ko ma gets sir. Kinda slow....[emoji3]
    Sent from my VTR-L29 using Tapatalk
    Should you really shift to neutral when stuck in traffic? | Top Gear Philippines
    With automatic transmissions, the engine is energizing or driving the transmission to move in the direction of the gear you've selected--forward or reverse. When you keep it in gear, you are telling your vehicle to move; when you're on the brakes, you're preventing motion. You're unnecessarily and slowly raising your automatic transmission fluid, wearing out your transmission clutches, and consuming more fuel because you're on the brakes to keep the car from inching forward. You're also unnecessarily wearing down and heating up your brake pads. By simply shifting to N or neutral there would be no need to apply the brakes with the amount of force required to resist forward motion.
    Oct 2014
    Thank you sir.[emoji106]
    Aug 2018
    Iba naman ang sabi dito (3:28) [emoji37]
    5 Things You Should Never Do In An Automatic Transmission Car! - YouTube
    Feb 2014
    hindi reliable yan top gear na yan
    pag old school slushbox a/t, yes you should put to neutral
    pag meron slushbox in front of the CVT, yes shift to neutral
    pag DCT, no need. the clutches disengage when you step on the brake
    pag meron clutch in front of the CVT, probably no need to neutral for the same reason as DCT
    experts are welcome to correct me
    Quote Originally Posted by Vodka View Post
    DCTs and CVTs need not shift to Neutral at long traffic stops. However, that does not stop people from doing it out of habit. On my end, I don't want to step that long on the brake pedal and also, accidentally letting go of the brake pedal at a stop with Drive engaged might cause you to bump the car in front.
    This is when I really appreciate the brake hold function in the CR-V. During long stops I can rest my legs.
    Nov 2018
    Got it. Thanks.[emoji106]
    base s experience ko n nabitawan ko ung brake at nka D ako ayun nabangga ko ung tricycle s harap ko. buti at plaka ko lng ang nagasgasan.. lesson learned nrin pg trapik, mag shift s N at mg handbrake pra mrelax dn mga binti..
    Quote Originally Posted by dirkmunitzky View Post
    i believe many motoring journalists will agree with you. putting it on N during longer waits, is the more logical thing to do.
    Jul 2013
    Well, in other countries... Kung traffic light lang, I keep it at "D"
    Pero Philippine traffic kung saan minsan 10 mins na di pa din gumagalaw... Different story.
    My personal rule...
    If I will use the handbrake... Linalagay ko muna sa "N"
    Aug 2018
    My personal rule...
Battle of the Transmissions: M/T vs. A/T
