Results 491 to 500 of 1576
June 24th, 2010 08:29 PM #491
Wow all these years as long as I am in first gear I never let go of the clutch completely and just release it when I shift to 2nd...
I assume same thing with Reverse, or do I need to still partially apply the clutch on Reverse?
June 24th, 2010 11:13 PM #492
safer kung naglalaro lang sa clutch pag reverse. mas malakas kasi ang hatak ng reverse over-all against sa 1st gear. in my experience
at 1st gear, i can fully release the clutch with slight on the gas pedal at 1.2-1.5 rpm. lalo pag continuous but slow moving traffic. kahit di pa umaangat yung needle ng speedometer.
June 24th, 2010 11:22 PM #493
^^Yeah I was so ignorant all along kala ko kasi dati basta 1st gear pag bitaw sa clutch patay ang makina yun pala hindi... In fact just tonight on my way home I tried it on my Yaris and even the car is just crawling maksin mga 10km/h lang swabe na sya even if I release the clutch... So manual ain't so bad in traffic afterall basta gumagalaw lang...
June 25th, 2010 08:42 AM #494
- Dec 2009
- 683
June 25th, 2010 08:51 AM #495
June 25th, 2010 11:03 PM #496
Oh, mapapagod ka nga nyan, same thing during reverse, as long as mahaba and you really need a fast pace, pwede bitawan clutch. In diesel, you can even release the clutch smoothly without depressing the accelerator and still the car would crawl - basta flat and wag lang uphill. Very helpful on heavy traffic. Sobrang lakas ng torque.
June 25th, 2010 11:07 PM #497
^^Actually sa gas pwede din ginagawa ko na rin yan dati ang hindi ko ginagawa na ngayon ko lang nalaman is totally let go of the clutch on 1st... Pero yung slightly letting go of the clutch to make the car roll without applying gas yes been doing that for years...
June 25th, 2010 11:10 PM #498
June 25th, 2010 11:13 PM #499
June 25th, 2010 11:15 PM #500
Pangit nga lang is on 1st gear without clutch applied ang lakas ng engine brake so medyo violent yung jerk ng car if you let go of the gas pedal...
Hello po. Buhayin ko itong thread on L300 and to give my experience with the 2020 Mits L300 and ...
[2020] Mitsubishi PH L300 recall (seat strap)
