Results 71 to 80 of 135
August 24th, 2013 10:36 AM #71
August 24th, 2013 10:38 AM #72
- Aug 2008
- 405
August 24th, 2013 12:02 PM #73If I would buy a pickup for my lady, I would buy her strada. If she would by one for me, I'll tell her hilux please....
- Apr 2008
- 6,235
August 24th, 2013 07:13 PM #74Regarding my friend with the Montero, he was plain lucky his car didn't conk out when he forded that. Being a matic, there wasn't much pedal work involved, so I wouldn't be bowing down to his skills anytime soon.
I see the Montero seems to be your dream car.The Strada's not far off though. Wading depth is just as good and performance is somewhat better due to lesser weight. If you want, you can always change the front fascia, install fender flares and 17'' Montero mags...
As per the spec sheet, the Strada GLX dimensions check in at 5115mm length, 1750mm width and 1775mm height. That's longer than even the current Pajero, let alone the Gen 1 Pajero. The length takes some getting used to, though it should't be too much effort if you drive it on a daily basis. A backup camera would be a very welcome investment though, especially if you opt to install a canopy, which reduces rear visibility even more. With the tint on the rear window still on, rear visibility is basically zero!
Ours has the optional power rear window so I can get away with a little visibility still...
- 172
August 24th, 2013 08:28 PM #75driving a truck means checking your side mirrors especially upon making turns on those narrow side streets with tricycles parked on the dead corner. it takes a lot of getting used to it....i suggest you get a steering knob. the rewards are great though, 700 kms on a full tank of diesel (70 liters).
on flooded streets, if a city bus can make it so can i. shuttled 10 people from picc to our place via espana ave last sunday.
you just have to get used to the tagtag. if the joints hurt take the sedan on a good day, but the fuel bills come iam sure the truck will be the vehicle of choice.
August 24th, 2013 10:36 PM #76
Have you considered an Innova? It's diesel, higher ground clearance than a sedan, shorter than a pickup.
August 25th, 2013 12:22 AM #77
yes the Montero is my dream car. In white
We used to have a B22 pick up that I could drive. I wonder if the Strada is longer? I think I am leaning towards the Strada but I will wait for that test drive first. The Hilux E in red is nice din kasi. I plan on adding a campershell pero wag na lang. heheh.
I like the G innova but it is above my budget. Plus I would also prefer to have a vehicle that is "global" and not just for the Asian market. Also, wasn't there an issue with the D4D of innova?
August 25th, 2013 12:33 AM #78
Wala na yung D4D issue cat, tagal na nasolve nun. Mga first few batches lang ng innova nagkaron ng ganun
Sent from my GT-P7310 using Tapatalk 2
August 25th, 2013 12:35 AM #79
August 25th, 2013 12:42 AM #80
I believe Fire Engine Red (as in TV5 red) color is available for G variants only.
Apart from TV5, Meralco, and Red Cross, I don't see many private owners putting up a camper shell.
Camper Shell, 80's ang dating.
Diesel is better, as long as maintenance is followed.Last edited by number001; August 25th, 2013 at 12:44 AM.
