Results 11 to 12 of 12
- Jan 2007
- 1,083
January 9th, 2020 03:28 PM #11SEO bot ata. Trabaho nyan is to sneak in links to raise their page rank. Dapat wag sagutin at lalong lano na wag i-quote it para ma-delete ng buo yung post nila kasama yung links. Nangyari kasi ngayon may nag quote na so kahit tinanggal na ng admin yung original post nya andito pa din sa forum yung links dahil naka quote sa post ibang user.
- Nov 2002
- 11
January 11th, 2020 08:22 AM #12I owned an '11 1.6V for five years and here are the issues which every long term owner more or less experienced with that gen corolla:
1) Ignition coils fail at 40k - 50k kms
2) replaced rack and pinion and drive column at 30k kms
3) oil sludge issue (should be ok if owner used fully synthetic oil and changed diligently)
It was a comfortable car that averaged 7-9 in the city and 10-12 in the highway. Make sure you check the above have been replaced already and also get the 2010 or later versions which have a dual vvti engine.
Truck / bus tires sometimes have markings on the side "regroovable" I think that MVIS should be...
[AutoIndustriya] Tires older than 5 years old not...
