Results 11 to 15 of 15
April 18th, 2007 12:10 AM #11
ceramic sockets available sa banawe, yung hardware na nag-iisa dun between kaliraya and the hospitals, 60 pesos each.
good enough na daw yung plastic sockets sa 100w and below. you'll need ceramics for anything higher than that value.Last edited by shampooking; April 18th, 2007 at 12:11 AM. Reason: added info
April 18th, 2007 12:17 PM #13
malaking tulong ba talaga ito ng headlight? gusto ko din sana palagay eh. naka ceramic socket na ko pero wala pang relay.
Sabi naman sakin dun sa Warren sa Binondo, pwede naman daw gawin yon .. binibigyan lang ako ng 2 relay tapos daw bili na lang daw ako ng wire. Ganon lang ba ka simple yon? kasi yung 2 relays with terminals na ay 200 pesos lang.
April 18th, 2007 12:27 PM #14
Malaking tulong sya for older cars. Old wires corrode and degrade.
Add a fuse for each relay, some wires, solder, electrical tape, 4 ring terminals, 3 male terminals, a wiring diagram and you're all set.
BTW you might want to replace the wires (if any) that come with the relay terminals as they usually are too thin (gauge 14 or 16 lang ata). You will need 5 female terminals for each relay terminal.Last edited by JohnM; April 18th, 2007 at 12:35 PM.
