Results 1 to 15 of 15
    Aug 2004
    Quote Originally Posted by shampooking View Post
    Jeff Tan sells that headlamp wiring harness relay kit for P650 petot. Sure enough, plug and play lang.
    Ceramic sockets na ba? Most of the kits sold in stores only use plastic hi-temp sockets AFAIK.
    Feb 2007
    Quote Originally Posted by SeminaristaKuno View Post
    Nope. Plastic eh, but I think it will suffice. Either way, I'll look for those. Bolt-on naman eh, makes use of those spade terminals.
    mga sir tanong lang po, i want to add a couple of lights to compliment the main headlights tulad ng mga setup ng cars nowadays.. and gusto ko, meron siyang sariling switch.. balak ko po sana lagyan ng fuse para safe incase na magshort.. maganda ren po bang lagyan ito ng relay? direkta po ito sa battery? paturo naman po ng proper installation mga sir! thanks po!!!
    Feb 2004
    checked blade sa rob metro east wala daw silang headlamp wiring kit.
    Feb 2007
    ceramic sockets available sa banawe, yung hardware na nag-iisa dun between kaliraya and the hospitals, 60 pesos each.
    good enough na daw yung plastic sockets sa 100w and below. you'll need ceramics for anything higher than that value.
    blade outlet sa market market may stocks pa
    malaking tulong ba talaga ito ng headlight? gusto ko din sana palagay eh. naka ceramic socket na ko pero wala pang relay.
    Sabi naman sakin dun sa Warren sa Binondo, pwede naman daw gawin yon .. binibigyan lang ako ng 2 relay tapos daw bili na lang daw ako ng wire. Ganon lang ba ka simple yon? kasi yung 2 relays with terminals na ay 200 pesos lang.
wiring & relay installation
