Results 1 to 15 of 15
    Apr 2003
    can it be done without cutting any of the oem wiring? want to install sana for headlights and horn but gusto ko sana yung plug and play lang. Company car kasi so I have to return everything back to stock.
    Last time nagpainstall ako sa other car namin, pinutol kasi nila yung existing terminals.
    Aug 2004
    When I upgraded my headlight wiring I didn't cut any of the original wires. Bili ka lang ng spade terminals na magkasya sa original headlight socket.
    Sa horn pwede rin. Spade terminals lang. No cutting needed.
    HTH
    Apr 2003
    okay. thanks. will do that pag nagpaupgrade na ko.
    OT. pwede bang mag-install ng amp without ripping out the console to get to the headunit? kaya ba yun iinstall from the wires leading to the speakers? Like if I wanted to add an amp and sub pwede b?
    again think company car and plug and play dapat para pag ibabalik na.
    Feb 2007
    regarding the OT... the HU would be taken out still for the SUB terminal located at the back of the HU. Tapping on the wires running to your speakers could create static.
    Kina Glenn sa Kamias walang cutting din. Bagong power line direct from the battery to the relay. Yung old power line, ang silbi lang niya is to switch the relay on or off but the juice comes from the new wire na rekta sa battery. New ground wire also.
    Kung sa headlamps, may DIY plug and play kit na binebenta sa BLADE.
    If you have the correct tool (e.g. the metal key for Pioneers), you can just use it and pull out the HU then install the wires behind it.
    Pero minsan, mas madali pang baklasin na lang yung dash ng konti kasi mas kita ko yung likod. If you do not know how, just watch the guy that will install it. Yung pagtanggal, pwede mo nang DIY. Yung system ko ako na nagtanggal nung binenta ko. Madali lang pala, isang gabi lang. hehehe.
    Feb 2007
    Jeff Tan sells that headlamp wiring harness relay kit for P650 petot. Sure enough, plug and play lang.
    Aug 2004
    Quote Originally Posted by shampooking View Post
    Ceramic sockets na ba? Most of the kits sold in stores only use plastic hi-temp sockets AFAIK.
    Feb 2007
    Quote Originally Posted by SeminaristaKuno View Post
    Nope. Plastic eh, but I think it will suffice. Either way, I'll look for those. Bolt-on naman eh, makes use of those spade terminals.
    mga sir tanong lang po, i want to add a couple of lights to compliment the main headlights tulad ng mga setup ng cars nowadays.. and gusto ko, meron siyang sariling switch.. balak ko po sana lagyan ng fuse para safe incase na magshort.. maganda ren po bang lagyan ito ng relay? direkta po ito sa battery? paturo naman po ng proper installation mga sir! thanks po!!!
    Feb 2004
    checked blade sa rob metro east wala daw silang headlamp wiring kit.
    Feb 2007
    ceramic sockets available sa banawe, yung hardware na nag-iisa dun between kaliraya and the hospitals, 60 pesos each.
    good enough na daw yung plastic sockets sa 100w and below. you'll need ceramics for anything higher than that value.
    blade outlet sa market market may stocks pa
    malaking tulong ba talaga ito ng headlight? gusto ko din sana palagay eh. naka ceramic socket na ko pero wala pang relay.
    Sabi naman sakin dun sa Warren sa Binondo, pwede naman daw gawin yon .. binibigyan lang ako ng 2 relay tapos daw bili na lang daw ako ng wire. Ganon lang ba ka simple yon? kasi yung 2 relays with terminals na ay 200 pesos lang.
    Aug 2004
    Quote Originally Posted by wrcastro_ph View Post
    Malaking tulong sya for older cars. Old wires corrode and degrade.
    Add a fuse for each relay, some wires, solder, electrical tape, 4 ring terminals, 3 male terminals, a wiring diagram and you're all set.
    BTW you might want to replace the wires (if any) that come with the relay terminals as they usually are too thin (gauge 14 or 16 lang ata). You will need 5 female terminals for each relay terminal.
    Thank you po sa reply sir.
wiring & relay installation
