Yung iba nilalagay sa bumper(hindi yung plastic bumper cover) tapos dinadaan sa firewall yung wiring pabalik sa loob ng car.
Iba naman nasa loob ng trunk
the magnetic base of the "black box's" antenna is removable - may nut lang that holds it.
hindi na sagwa tignan sa labas![]()
May idea po ba kayo mga gurus kung paano paganahin yung tv plus sa isuzu mux 8n. Sinubukan ko na lahat meron na rin ako 3 rca jack pati aux to aux na 3 lines pero ang lumalabas lang sa monitor is "audio only" ayaw lumabas ng video pero meron sound. Pa help naman po thanks.
Mga boss, I’ve read somewhere na pede panoorin ang nba premium sa tv plus? Does any know how to? Nasscan ko lang sya, pero encrypted. Is there any way para mapanood sya? Thanks sa sasagot
We bought a second hand innova with TV plus already installed. Ang problem po, yung sa right side na headrest monitor, blue lang ang screen pero yung sa left side umaandar naman. May nagalaw po kayang wires dito? Nag o-on siya pero blue screen.
anybody tried installing TV plus on Pioneer 2 Din HU - AVH275BT? Wala syang separate Video in. Sa Aux input yung Audio - video nya using CD-RM10 cable ng pioneer. Mukha namang ordinary yellow-red-white RCA so ito yung binili ko sa ace hardware instead of the Pioneer cable.
The problem is hindi ko mapalabas yung Video sa screen saka parang iba yung config ng RCA ng pioneer since the ordinary RCA cable sa Yellow and white yung audio tapos yung red puro static lang...
For now sa Reverse camera in ko nilagay yung video signal yun nga lang may nakalagay na Cution The image may appear reversed...
salamat mga sir![]()
Installed the TVplus with an aftermarket 2DIN i got from Hk and its working fine pati signal.
Problem ko is how to eliminate the whining sound coming out sa speakers.
Tried relocating every wire naka ilan lipat nako ng locations even the antenna to isolate the problem.
Tried na din the method on youtube na they groud loop the HU using short audio wire pero meron pa din.
Since ang ginamit ko na RCA cable is yung kasama ng kit box, may difference ba kung mag try ako ng branded RCA cable?
Thank you!
^yes poor quality cables leak signals exemplified as hum in speakers
Sent from my SM-G355H using Tapatalk
I used the supplied RCA cable of the TV plus and wala naman ako na-experience na speaker humm, although for isolation try ka na lang din ng ibang cable.
Power source ko is tapped at the second 12V socket though, ymmv
Sir, When you say second 12v socket, What do you exactly mean?
Ako kasi ang ginamit ko is yung lighter plug-to-power i got from Lazada. Then bumili din ako ng 2-in-1 lighter socket para share sila ng dashcam.
Inisip ko din na baka nag co-conflict sila ng Dashcam so ginamit ko ng unplugged yung dashcam pero meron pa'din.
The speaker humm i'm hearing from the speakers eh lumalakas while driving kasabay ng accelerator. Kay din na try ko yung sa Youtube na ground loop baka kasi kinakapos sa ground kaya sumasabay sa alternator.
