Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 106
    Jun 2005
    #21
    Yung iba nilalagay sa bumper(hindi yung plastic bumper cover) tapos dinadaan sa firewall yung wiring pabalik sa loob ng car.
    Iba naman nasa loob ng trunk
    Jun 2015
    #22
    gilid ng dashboard
    Sent from my SM-G610Y using Tapatalk
    #23
    Quote Originally Posted by sirkosero View Post
    may signal pa ba masasagap ito?
    ako plano ko sa rear windshield area. di naman metalized tint gamit ko so i guess OK lang magiging signal doon, sa dashboard or dito ko man ilagay. kahit paano di istorbo sa view while driving.
    Apr 2010
    #24
    the magnetic base of the "black box's" antenna is removable - may nut lang that holds it.
    hindi na sagwa tignan sa labas
    Sep 2016
    #25
    May idea po ba kayo mga gurus kung paano paganahin yung tv plus sa isuzu mux 8n. Sinubukan ko na lahat meron na rin ako 3 rca jack pati aux to aux na 3 lines pero ang lumalabas lang sa monitor is "audio only" ayaw lumabas ng video pero meron sound. Pa help naman po thanks.
    Oct 2009
    #26
    Quote Originally Posted by pomporumpum View Post
    tingnan mo muna sa manual ng stereo kung may audio video.AV in or AV aux.kung wala..sound lang talaga mapapagana mo dyan.
    Nov 2017
    #27
    Quote Originally Posted by SW21 View Post
    Saka High gain Car TV antenna with booster.
    where can i buy high gain car antenna with booster?
    thanks!
    Jul 2010
    #28
    Mga boss, I’ve read somewhere na pede panoorin ang nba premium sa tv plus? Does any know how to? Nasscan ko lang sya, pero encrypted. Is there any way para mapanood sya? Thanks sa sasagot
    Nov 2017
    #29
    We bought a second hand innova with TV plus already installed. Ang problem po, yung sa right side na headrest monitor, blue lang ang screen pero yung sa left side umaandar naman. May nagalaw po kayang wires dito? Nag o-on siya pero blue screen.
    May 2011
    #30
    Quote Originally Posted by rickbee View Post
    thanks!
    Up on this, saan nakakabili nito? Ayoko may antenna sticking sa bubong eh, yung radio ko wala rin antenna.
    Aug 2012
    #31
    Quote Originally Posted by noncommuter View Post
    Check the video cables.
    Sent from my ASUS_X00DDA using Tapatalk
    #32
    baka mali lang yun color coding ng rca mo try mo pag palit palitin yun 3 rca try firs video then saka audio.
    Sent from my SM-J700H using Tapatalk
    May 2015
    #33
    anybody tried installing TV plus on Pioneer 2 Din HU - AVH275BT? Wala syang separate Video in. Sa Aux input yung Audio - video nya using CD-RM10 cable ng pioneer. Mukha namang ordinary yellow-red-white RCA so ito yung binili ko sa ace hardware instead of the Pioneer cable.
    The problem is hindi ko mapalabas yung Video sa screen saka parang iba yung config ng RCA ng pioneer since the ordinary RCA cable sa Yellow and white yung audio tapos yung red puro static lang...
    For now sa Reverse camera in ko nilagay yung video signal yun nga lang may nakalagay na Cution The image may appear reversed...
    salamat mga sir
    Apr 2018
    #34
    Quote Originally Posted by red_one View Post
    -kunin nyo po yung mismong tv plus at ikabit nyo po muna sa t.v nyo sa bahay ,
    go to settings , iclick nyong resolution dapat below 720p, save nyo po yung setting.
    tapos ikabit nyo ulit si tv plus sa kotse ..gagana na po yan sa size ng screen ng head unit nyo .
    Aug 2014
    #35
    Installed the TVplus with an aftermarket 2DIN i got from Hk and its working fine pati signal.
    Problem ko is how to eliminate the whining sound coming out sa speakers.
    Tried relocating every wire naka ilan lipat nako ng locations even the antenna to isolate the problem.
    Tried na din the method on youtube na they groud loop the HU using short audio wire pero meron pa din.
    Since ang ginamit ko na RCA cable is yung kasama ng kit box, may difference ba kung mag try ako ng branded RCA cable?
    Thank you!
    Dec 2009
    #36
    ^yes poor quality cables leak signals exemplified as hum in speakers
    Sent from my SM-G355H using Tapatalk
    Apr 2012
    #37
    Quote Originally Posted by page7fordoddie View Post
    Thank you!
    most likely. check also your source. kung via usb an anti-jitter device will help.
    Aug 2014
    #38
    Thank you!
    Will look for a higher end RCA muna thats easier to find. Will update this thread ASAP.
    Apr 2010
    #39
    I used the supplied RCA cable of the TV plus and wala naman ako na-experience na speaker humm, although for isolation try ka na lang din ng ibang cable.
    Power source ko is tapped at the second 12V socket though, ymmv
    Aug 2014
    #40
    Sir, When you say second 12v socket, What do you exactly mean?
    Ako kasi ang ginamit ko is yung lighter plug-to-power i got from Lazada. Then bumili din ako ng 2-in-1 lighter socket para share sila ng dashcam.
    Inisip ko din na baka nag co-conflict sila ng Dashcam so ginamit ko ng unplugged yung dashcam pero meron pa'din.
    The speaker humm i'm hearing from the speakers eh lumalakas while driving kasabay ng accelerator. Kay din na try ko yung sa Youtube na ground loop baka kasi kinakapos sa ground kaya sumasabay sa alternator.
    Quote Originally Posted by ParticleX View Post
TV Plus Car Installation
