Results 41 to 50 of 106
- Apr 2010
- 739
June 19th, 2018 12:47 PM #41i have two front power sockets kasi,
one power socket is plugged into a 3-port splitter:
2 x micro usb chargers for the second row seats
1 x dashcam
I soldered the tv plus power wires inside the splitter
i use the other power socket for the usb charger of the front seats or for a tire inflator
possible sa grounding nung head unit mo ang issue, do you still hear the humming noise on other inputs (radio, video, etc?)
June 19th, 2018 02:05 PM #42
Ah gets so almost the same pala with what you did,... So eliminate ko na sa suspect yung power source cable.
Kaya medyo sure ako na sa RCA cable galing yung problem is kasi sa AUX lang sya may humm, zzzz sound (Normal ang USB, Radio, SD Card)
Maybe the best move for me is to really get a good RCA cable then try ko ulit i-gound ng mas maayos this time.
Will update this thread ASAP para sa iba pang forumers having the same problem.
Thanks alot Sir!
June 19th, 2018 11:07 PM #43
Get a regulated power supply for your TV+ instead of changing the audio cable (i presume is a RCA to headphone jack)
Voltage on the lighter socket varies from 13.5V to 14.5V when the engine is running
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; June 19th, 2018 at 11:39 PM.
June 20th, 2018 07:01 PM #44
If nagpepersist pa rin yung humming sound mo kahit nagpalit ka na ng RCA, bili ka ng ground loop isolator.
Malaki chance na solve yang issue mo.
June 23rd, 2018 12:12 AM #45
June 24th, 2018 02:52 AM #46
Update: a more expensive RCA cable did not work ganun pa din. Maybe next step is to use ground loop isolator.
Question: iba ba ang isolator for audio at for video? Kasi tried to search online and on youtube may recommended sila yung Mpow na brand maganda review & price is okay naman at P650. Kaso baka pang audio lang ito? O pwede din to sa video usage like TV plus.
Sa ngayon ang remedy ko is to lower the treble ng HU sa settings. The higher the treble the more iritating kasi the noise.
- Apr 2010
- 739
June 24th, 2018 08:38 AM #47isolate mo muna,
same issue pa rin ba when a different source is plugged into the same input? try a RCA-to-3.5mm jack and play audio files to see if humming persists
borrow/beg/steal a 12v (at least 2A i think)! car cigarette adapter or if you have a long 220v extension going to your car, use the included AC adapter para ma troubleshoot power issues
June 24th, 2018 11:55 AM #48
When you clarified the situation i realized the culprit could be the power voltage you supply with the TV+
When engine is off, NO hum on your set up right
Only when the engine is running that the hum gets pronounced
Voltage output varies from 12V to 13.5V to 14.5V frm engine off to engine running
Apply a regulated 12V output when the engine is running on your TV+ to get rid of the hum
June 24th, 2018 04:16 PM #49
- Aug 2012
- 2,767
June 24th, 2018 08:17 PM #50
I dont know kung ano ang major contirbutor sa incident nayan. Dahil ba made in china yung ev car o...
Hybrids and EV
