Results 31 to 40 of 106
- Aug 2012
- 2,767
February 3rd, 2018 07:02 AM #31
March 4th, 2018 10:01 AM #32
- May 2015
- 16
March 11th, 2018 01:24 PM #33anybody tried installing TV plus on Pioneer 2 Din HU - AVH275BT? Wala syang separate Video in. Sa Aux input yung Audio - video nya using CD-RM10 cable ng pioneer. Mukha namang ordinary yellow-red-white RCA so ito yung binili ko sa ace hardware instead of the Pioneer cable.
The problem is hindi ko mapalabas yung Video sa screen saka parang iba yung config ng RCA ng pioneer since the ordinary RCA cable sa Yellow and white yung audio tapos yung red puro static lang...
For now sa Reverse camera in ko nilagay yung video signal yun nga lang may nakalagay na Cution The image may appear reversed...
salamat mga sir
- Apr 2018
- 2
April 13th, 2018 03:42 PM #34
June 18th, 2018 02:30 PM #35
Installed the TVplus with an aftermarket 2DIN i got from Hk and its working fine pati signal.
Problem ko is how to eliminate the whining sound coming out sa speakers.
Tried relocating every wire naka ilan lipat nako ng locations even the antenna to isolate the problem.
Tried na din the method on youtube na they groud loop the HU using short audio wire pero meron pa din.
Since ang ginamit ko na RCA cable is yung kasama ng kit box, may difference ba kung mag try ako ng branded RCA cable?
Thank you!
June 18th, 2018 07:58 PM #36
^yes poor quality cables leak signals exemplified as hum in speakers
Sent from my SM-G355H using Tapatalk
June 18th, 2018 08:20 PM #37
June 18th, 2018 10:19 PM #38
- Apr 2010
- 742
June 19th, 2018 10:13 AM #39I used the supplied RCA cable of the TV plus and wala naman ako na-experience na speaker humm, although for isolation try ka na lang din ng ibang cable.
Power source ko is tapped at the second 12V socket though, ymmv
June 19th, 2018 12:26 PM #40
Sir, When you say second 12v socket, What do you exactly mean?
Ako kasi ang ginamit ko is yung lighter plug-to-power i got from Lazada. Then bumili din ako ng 2-in-1 lighter socket para share sila ng dashcam.
Inisip ko din na baka nag co-conflict sila ng Dashcam so ginamit ko ng unplugged yung dashcam pero meron pa'din.
The speaker humm i'm hearing from the speakers eh lumalakas while driving kasabay ng accelerator. Kay din na try ko yung sa Youtube na ground loop baka kasi kinakapos sa ground kaya sumasabay sa alternator.
Very tragic. Looks like it destroyed one of the bollards. The bollards seem designed to stop sedans...
