why not try this fractal antenna. yan ang gamit ngayun sa mga cellphones.
The first thing I would like to discuss is a little history, theory, and uses for fractal antennas.
Fractal antennas are a recent discovery. First discovered back in 1988 by Nathan Cohen and later published and patented in 1995. A fractal antenna has a few unique attributes as seen in this definition from Wikipedia:
"A fractal antenna is an antenna that uses a fractal, self-similar design to maximize the length, or increase the perimeter (on inside sections or the outer structure), of material that can receive or transmit electromagnetic signals within a given total surface area or volume."
What exactly does that mean? Well, you need to know what a fractal is. Also from Wikipedia:
"A fractal is generally a rough or fragmented geometric shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,a property called self-similarity."
So basically, a fractal is a geometric shape that repeats and appears over and over no matter how far out or how far in you zoom magnification. For visual clarification, here is a picture of the patented antenna:
Source: Wikipedia and http://patimg2.uspto.gov/.piw?PageNu...id=US007088965 Patent number: 7088965]
From this website: How to make a fractal antenna for HDTV / DTV plus more on the cheap http://ruckman.net/blog/news.php?item.21.4
HTH
