Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    #21
    I'm using an internal type and I frequent Cavite rin naman. Reception's fine, you just simply have to fine-tune the frequency your tuner's currently in (for example, 55.25 ang Channel 2, if kumukurap, try fine-tuning it to 54.85 or 55.45, whatever gives you a better picture clarity without losing the audio). And kung wala namang audio kahit anong gawin niyo, try changing the RF Frequency from Europe, Japan, etc., to USA1 or USA2 (normally seen on generic China-made HU's).
    Same applies for NCR areas provided you're not below a bridge or traversing through a tunnel. Just my .02. Will take a pic of mine, just bought it from Raon at 900 petot sa PAUL VINCENT almost a year ago, may booster na at included na rin yung adaptor for different TV-ANT plugs in some HU's.
    Pros: retractable yung antennas niya; channels mentioned by TS is clear; 3M windshield adhesive included; with booster; and pretty much concealed.
    Cons: signal splitter for HU's that needs a 4-plug type antenna can be hard to find.
    Oct 2008
    #22
    Quote Originally Posted by LadyRider View Post
    Hello mga Sirs! Good day! Gusto ba ninyo i-rephrase ang title ng thread na ito?
    Since you are talking about "Car Antennas", why don't we change it kung ok lang naman sa thread starter? What do you think po?
    'la problema yan ma'm
    #23
    Quote Originally Posted by mitsukorin View Post
    bro ilan bang antenna ang gamit mo? yung nabili mo ba sa concorde kahit magisa lang ito maganda pa rin reception? thanks
    May 2005
    #24
    Quote Originally Posted by batang_raon14 View Post
    Sir, can i ask a favor? Pwede mo ba i-list yung frequency ng mga channels na ginawa mo? Yung sa akin kasi walang masagap na signal dito sa lugar namin. Baka pag-naset ko na at moving na madali na makakuha ng signal. Salamat po in advance!
    Mar 2005
    #25
    mga bros ntsc ba tayo dito o pal? kasi eto yung mga options ko to get reception sa tv ko sa car.
    so far di ako makahanap ng channel. ano ba ang mhz or frequency on specific channels.
    Ty
    Dec 2008
    #26
    Quote Originally Posted by jasonub View Post
    Ty
    bro, philippines is using an ntsc signal..
    Dec 2007
    #27
    thanks ma check nga sa concorde
    Oct 2008
    #28
    hello po, share ko lang mga fellow tsikoteers, may nabili ako tv antenna last sunday at masasabi na ito na ang pinaka magandang reception sa mga nasubukan ko(i've had four!:praning ang brand name nya "Super Road" made in japan medyo pricey 1,999 at external. Sulit naman po dahil maganda ang reception ng mga channels 2,7,23,Q etc. Umuwi ako hangang cavite malapit na tagaytay, channel 2 medyo kumukurap, pero Channel 7 excellent reception all the way and so are other channels.
    IMO:
    pros-ganda reception, no external power required, removable slide on/slide off para di "mapitas" sa parking, quality built pulido ang gawa kahit plastic ang casing
    cons-pricey, external
    sir anong tv tuner po gamit nyo? yung sakin kasi avt super labo talaga kahit anong channel and ang antenna na gamit ko is yung kasama sa package na internal na may 2sets 2 tingting and 1 box nakadikit sa upper left and upper right ng windshield.. tia
solved my tv reception problem
