Results 41 to 49 of 49
October 16th, 2017 07:07 AM #41
c9 pro gamit ko bro eh
may nagsabi kasi sa pdvd, na yung a7 nya sa wall charger adaptive fast charging pero pag sa car charger di nag fast charging. pero nung s7 na daw phone nya both wall and car charger nag adaptive fast charging naman daw.
Baka pang high end lang yun fast charger sa auto lolLast edited by ninjababez; October 16th, 2017 at 08:22 AM.
October 18th, 2017 04:21 AM #42
- Oct 2014
- 1,232
July 28th, 2020 05:00 AM #43
July 28th, 2020 08:10 AM #44
I have an old car inverter. I got it way back in 2005 when I was still working in Minneapolis. I still use it when we are on road trips.
- Oct 2014
- 1,232
July 28th, 2020 08:47 AM #45
July 28th, 2020 09:32 AM #46
July 28th, 2020 10:24 AM #47
I have a small 200W model which I got from CDR-K a long time ago. I don't use it much but when I do, it's for charging my laptop (90W) in between meetings while in the field. I've also used it to charge my drone batteries on the road.
One thing you need to pay attention to is the rating of your cigarette lighter socket. Most are just 10 or 15A. That means, at 15A, it can only deliver 180W max (before the inverter). If you factor in the inverter (which also use up power for itself and therefore, you lose some efficiency), the output power post-inverter will be slightly lower still:
P = V x A x Inverter Efficiency
where:
P = Max inverter power output
V = Typical supply voltage
A = Max supply current
Inverter efficiency (Typical) = 85%
So for a vehicle with a 12V, 15A power socket:
12V x 15A x 0.85 = 153W
But if you connect your inverter to a 10A socket:
12V x 10A x 0.85 = 102W
TL;DR: If your load is at or approaching the power limits of your cig lighter socket, consider having either a dedicated wiring (fused) for the inverter or simply use the alligator clips and attach it directly to the battery (obviously, the latter is applicable only when the vehicle is stationary).
You risk popping a fuse at best or ruin your vehicle's wiring and/or cause a fire at worst if you don't keep an eye on your loads. That's why I opted for a smaller inverter. I would surely trigger the overload protection on the inverter first before potentially overloading the vehicle's electrical system.Last edited by oj88; July 28th, 2020 at 10:28 AM.
July 30th, 2020 08:16 PM #48
- Jan 2007
- 2,593
July 31st, 2020 01:35 AM #49
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
