Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Aug 2007
    one amp for the sub and one amp for the seperates(front and back stage) do i need two amp???
    cuz 1 installer told told me that 1 amp can drive all of them sub and seperates(fornt and back stage)
    and the other said you need two amp one for the sub and one for the seperates(fornt and back stage)
    i just want to know kung ano talga ang totoo!
    setup street bass
    If it's for bass... I would rather have separate amps for the sub and for the rest of the speakers.
    Aug 2004
    depende sa sub nyo, sir. if power hungry yung sub then i suggest better get a mono amp then another 2ch para sa fronts nyo.
    anong sub ba gamit nyo, sir at ano power rating nito?
    May 2005
    Quote Originally Posted by wicked_jester View Post
    setup street bass
    ilan b ang speaker mo bro at ilan ang sub mo?
    kung apat ang speaker mo (front and rear), u need 4 channel amp to power them.
    and kung 1 lng ang sub mo, u need 2 channel amp.
    bale 2 amp nga kelangan mo (4channel amp for the front and 2channel amp for the sub).
    kung gusto mo 1 amp lng, ung seps at sub ang ikabit mo sa amp then ung rear speaker mo sa head unit n lng.
    hope this helps.
    ano sub mo?
    ano separates mo?
    ano amp mo?
    kung tingin mong kaya ng amp mo ok lang.
    Aug 2007
    ito po ung mga gamit ko sirs
    specs:
    sub= brutus BX15d2 700rms
    seps= ZXi 6.5c 100 rms
    coax= pioneer TS-A1682S 240w
    6x9 pioneer stock 25w
    Nov 2006
    you can get a 5 channel amp and it can power all 5 speakers/sub but i doubt that theres any 5 channel amp with a sub channel that can produce a clean 700W RMS so you might as well get 2 amps.1 amp(4channel 50 X 4) for your front and back speakers and 1 monoblock or class D amp for the sub.you dont need a 2 channel amp for a sub.
    the question is....can your car handle the extra load?
    Aug 2007
    ang car ko po is MAZDA 323F 1.3(1999 model)
    alternator= 65A
    Battery= good condition
    kaya po ba?
    Aug 2004
    mukhang kaya naman, bro.
    get 1 4ch amp for the seps and coax
    then 1 mono amp for the sub
    dagdag ka narin ng caps if may extra budget
    para sure na malinis at hindi ka kakapusin sa power.
    Aug 2007
    ano po magnda sa dalawa
    ang sub po ay 700rms at DV 2 OMHS
    itong amp na ito
    http://www.lanzar.com/itempage.asp?MODEL=VIBE226
    o ito po
    Hifonics Titan TXi-6006 2 Channel A/B Amplifier
    http://www.bizrate.com/caramplifiers/hifonics-titan-txi-6006-2-channel-a-b-amplifier--pid415455461/
    Oct 2005
    Quote Originally Posted by antonmace
    makikisingit lang po... newbie questions: may i ask if ok yung suggestion ni sir antonmace? kasi po, sa case ko... nakabili na ako ng head unit (pioneer, yung deh1950 lang po)... i still use the stock speakers since working naman lahat.
    in a couple of weeks, may parating po kasi akong v12 705 amp (4ch). bale ano po kaya magandang gawin? ipapakabit ko po ba yung lahat ng 4 channels sa front and rear speakers? or front lang i-amp ko para yung 2 channels naka-abang na sa subwoofer? balak ko po kasi maliit na sub lang, mga 8" kasi for my own listening pleasure lang naman po.
    thanks!
    Jun 2006
    Quote Originally Posted by forbiddensmoke View Post
    thanks!
    Since budget meal setup, kabit mo fronts sa channel 1 and 2. Bridge mo 3 and 4 for your sub. Rear fill can be powered by your HU. Baka mabitin ka sa 8 inch kung kaya go for a bigger sub 10 or even 12 inches.
    Aug 2006
    itong amp na ito
    o ito po
    go for the hifonics much better if you can get a higher power models
    try this site:
    http://www.powertrip.com.ph/html/hifonics.html
    bro try mo JBL 75.4 II, para may room pa for upgrades. busog pa system mo.
    Aug 2007
    ok... thanks po
    Aug 2007
    mga mgakano po ung JBL 75.4 II naman?
    is nominal power RMS rin po ba iyon? kasi yun ung nakalagay sa COAX ko na pioneer 250w max at 50 nominal power, kung JBL 75.4 II ang magdrive nito d kaya masunog ang coax ko?
    Oct 2005
    Quote Originally Posted by userfriendly
    pasintabi po ulit sa thread starter...
    *userfriendly: ok sir... bale kanina po may nakita na akong pioneer speakers para sa front (doors)... since swak sa budget at mukhang ok naman specs. so papalitan ko nalang po muna yun front speakers. then pag dating nung v12 budget amp ko, ipapa-amp ko (sa channel 1 and 2) yung fronts tapos yung rear sa HU ko nalang ipapakabit para naka-abang yung channels 3 and 4 para sa sub just like what you have said. so ganun nalang po... i hope maging ok po yung kalabasan. nakaka-excite! thanks po!
    Aug 2006
    JBL GTO75.4 nasa 9 to 12k yata bnew
    Output Power at 14.4V and ≤1% THD+N (CEA-2006):
    4 x 104W * 4 ohms
    4 x 142W * 2 ohms
    2 x 284W * 4 ohms bridged
    S/N Ratio: 80dBA (1 Watt, 4 ohms)
    Effective Damping Factor: 6.384 at 4 ohms
    Freq. Response: 10Hz ∼ 83kHz (-3dB)
    Fuse: 2 x 30A
    Dimensions: 15.12" x 12.31" x 2.4" (38.41cm x 31.3cm x 6cm)
    http://ampguts.realmofexcursion.com/...n_outside1.jpg
    Aug 2007
    pero ung coax ko po ba hindi ba masunog pg jbl 75.4 ang magdrive? ano ba nominal power?RMS din ba ito? kasi nakalagay 280watt maxx 50 nominal power.
    so to power my coax is i need 50rms sa amp kasi nakalagay 50 nominal power tama ba po?? eh diba 104W ang per ch ng jbl 75.4 dba sobra yun?
    Aug 2007
    wicked_jester;937515]pero ung coax ko po ba hindi ba masunog pg jbl 75.4 ang magdrive? ano ba nominal power?RMS din ba ito? kasi nakalagay 280watt maxx 50 nominal power.
Is it necessary to have two amplifiers or just one???
