Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
    Aug 2006
    #21
    this is the trick:
    ! install your amp and drivers.
    2. before playin make sure if the volume control of your HU is set to 0
    3.check if the gain of the amp is set to its minimum.
    4. while playing set the volume of the HU to 12 oclock (1/2)
    5 slowly turn your gain of your amp to 9 oclock(1/4)
    6. do this till you reached the clipping point of the drivers then set it to its nominal possition so that even the hu was tured to its max the drivers still can ressist the powers of the amps!
    hope this helps good luck!
    Aug 2007
    #22
    ok ill try po! thanks....
    #23
    pasintabi po....
    existing pa ba ung Ultra Sound Acoustic (USA) na amp?
    Oct 2007
    #24
    kuha ka na lang ng hifonics TXi 6404 para straight hifonics ka.
Is it necessary to have two amplifiers or just one???
