Results 1 to 18 of 18
    Oct 2005
    i was wondering since i have a reciever (pioneer deh1950) with only 1 set of pre-outs, and i want to hook up a 4 channel amp with 2 sets of pre-outs, 1 being a sub pre-out, how would i go about doing this?
    i hope someone can give me some advice on it since i'm stuck on my current hu (matagal pa bago mag-upgrade ulit ).
    thanks!
    Jan 2004
    Quote Originally Posted by forbiddensmoke View Post
    thanks!
    What's your amp make and model?
    Oct 2005
    v12 805 sir... budget meal setup lang po kasi...
    Jan 2004
    I think what you're saying is your amp has 2 sets of line level inputs. Not too familiar with the v12 model but some amps will automatically send amplified signals to four speakers even with just one input. Try that.
    And what are you driving with the amps? How many speakers? If you have only one set (L+R) then you only need one input.
    Bili ka ng 2 Y-rca cable para maging 4 yung preouts mo.. 2 para sa sub at 2 para sa front speakers, yung rear speakers kahit wag mo na ikabit, o kaya idirect connect mo sa rear ng hu
    o kaya kung gusto mo, yung front speakers connect mo sa front ng hu, yung rear kahit wag mo na connect (optional), tapos yung preouts connect mo sa amp sub input, bridged kung isa lang sub mo, at kung may FIE (Front Image Enhancer) yung hu mo, set mo sa ON.. oks na yan ..
    yup. Y-rca lang katapat niyan. you wont have control over your fader function though
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Oct 2005
    sa pagkakaintindi ko po bale mawawalan ako ng control sa fader... bukod po dun, may magiging difference po kaya sa ovarall sq pag ini-split ko po ang rca preout ng hu ko?
    Aug 2006
    are you goin to compete? if so yes may mga disadvantages ang naka Y connectors when it comes to linis ng tunog! and if not, pwede naman sa SQ set nasa own preference lang yan! if it sound good to you it may not sound so good to others IMO
    Quote Originally Posted by toolightz View Post
    x2.. agree ako diyan! hehe
    I'm using the DEH-2950. 1preout. ok naman siya. I'm using Y-RCA. So far so good, no problems. I just have a simple setup, single 12" sub, 1 amp, seps. The sound is ok, but I plan to upgrade my headunit.
    Oct 2005
    nakabit na po sa wakas...
    btw, eto po pics na somewhat nagdedescribe kung ano ginawa mga sir... need your comments po.
    thank you very much!
    Aug 2005
    ok lang yan kahit 1set pre outs..tama sila...pero kung gusto mo talaga madami preouts pede ka mag active xover or benta mo yan hu mo at bili ka ng bago...=) ok na yan..2 yconector lang muna then test it kung ok na sayu...
    Oct 2005
    actually sir di po kami gumamit ng y-connector... sinuggest nung technician na pagsamahin nalang yung wires sa speaker... di nga lang ako 100% sure kung anung wires talaga yung pinagsama basta inapprove ko... pero nung tinesting na namin, ok naman. di naman sumabog yung hu ko...
    bale tulad ng sabi ni sir caloyski5, wala na silbi yung fader function ng hu ko... pero ayus lang. sa ngayon po ang dating sa pandinig ko mas naging clear ng dating ng boses at kalansing pati yung bass malakas pero malambot... naging balanse po. siguro dahil sa pagkaka-tweak ng amp.
    hay... wag lang sana ako matuksong mag-audition ng ibang system... kasi patay na... :D
    Aug 2006
    you mean cguro yung front and rear sa ch 1n2 3n4 sa subs? 2RCA sa input ng amp???diba 4 yung RCA inputs na V12? san kumuha ng signal yung isang ch???
    Oct 2005
    di ko rin po sure pero ang alam ko lang kasi sir yung rca from the hu, kinabit sa line out channel 3 and 4 ng amp (v12 805)... tapos yung rca terminals sa amp na channels 1 and 2 ni-link sa channels 3 and 4 using an ordinary rca cable.
    di kaya masira yung amp kasi dun sa output kinabit kesa sa input? pero pwede siguro kasi yung output 3/4 nakawire ata directly sa input 3/4???
    parang ganito ba?
    HU (R) --> 3 RCA OUT --- 3 RCA IN <--> 1 RCA IN
    HU (L) --> 4 RCA OUT --- 4 RCA IN <--> 2 RCA IN
    Oct 2005
    yup sir ganyan nga po parang yun sa illustration sa #11 post.
    sa totoo lang naguluhan ako kung bakit ganun ginawa. pero nasubukan ko naman magpatugtog around an hour straight... ok naman po, tama lang din init ng amp...
    Aug 2006
    ah i see! never tried that pa pero mukang safe naman yung amp! meron nga palang outs yung 805 kaya dun kukuha yung kabilang channel!
    sorry my bad
Reciever With Only 1 Set Of Pre-Outs
