Results 1 to 20 of 24
    Aug 2007
    ano po magnda sa dalawa
    ang sub po ay 700rms at DV 2 OMHS
    itong amp na ito
    http://www.lanzar.com/itempage.asp?MODEL=VIBE226
    o ito po
    Hifonics Titan TXi-6006 2 Channel A/B Amplifier
    http://www.bizrate.com/caramplifiers/hifonics-titan-txi-6006-2-channel-a-b-amplifier--pid415455461/
    Oct 2005
    Quote Originally Posted by antonmace
    kung gusto mo 1 amp lng, ung seps at sub ang ikabit mo sa amp then ung rear speaker mo sa head unit n lng.
    makikisingit lang po... newbie questions: may i ask if ok yung suggestion ni sir antonmace? kasi po, sa case ko... nakabili na ako ng head unit (pioneer, yung deh1950 lang po)... i still use the stock speakers since working naman lahat.
    in a couple of weeks, may parating po kasi akong v12 705 amp (4ch). bale ano po kaya magandang gawin? ipapakabit ko po ba yung lahat ng 4 channels sa front and rear speakers? or front lang i-amp ko para yung 2 channels naka-abang na sa subwoofer? balak ko po kasi maliit na sub lang, mga 8" kasi for my own listening pleasure lang naman po.
    thanks!
    Jun 2006
    Quote Originally Posted by forbiddensmoke View Post
    thanks!
    Since budget meal setup, kabit mo fronts sa channel 1 and 2. Bridge mo 3 and 4 for your sub. Rear fill can be powered by your HU. Baka mabitin ka sa 8 inch kung kaya go for a bigger sub 10 or even 12 inches.
    Aug 2006
    Quote Originally Posted by wicked_jester View Post
    itong amp na ito
    o ito po
    go for the hifonics much better if you can get a higher power models
    try this site:
    http://www.powertrip.com.ph/html/hifonics.html
    bro try mo JBL 75.4 II, para may room pa for upgrades. busog pa system mo.
    Aug 2007
    ok... thanks po
    Aug 2007
    mga mgakano po ung JBL 75.4 II naman?
    is nominal power RMS rin po ba iyon? kasi yun ung nakalagay sa COAX ko na pioneer 250w max at 50 nominal power, kung JBL 75.4 II ang magdrive nito d kaya masunog ang coax ko?
    Oct 2005
    Quote Originally Posted by userfriendly
    pasintabi po ulit sa thread starter...
    *userfriendly: ok sir... bale kanina po may nakita na akong pioneer speakers para sa front (doors)... since swak sa budget at mukhang ok naman specs. so papalitan ko nalang po muna yun front speakers. then pag dating nung v12 budget amp ko, ipapa-amp ko (sa channel 1 and 2) yung fronts tapos yung rear sa HU ko nalang ipapakabit para naka-abang yung channels 3 and 4 para sa sub just like what you have said. so ganun nalang po... i hope maging ok po yung kalabasan. nakaka-excite! thanks po!
    Aug 2006
    JBL GTO75.4 nasa 9 to 12k yata bnew
    Output Power at 14.4V and ≤1% THD+N (CEA-2006):
    4 x 104W * 4 ohms
    4 x 142W * 2 ohms
    2 x 284W * 4 ohms bridged
    S/N Ratio: 80dBA (1 Watt, 4 ohms)
    Effective Damping Factor: 6.384 at 4 ohms
    Freq. Response: 10Hz ∼ 83kHz (-3dB)
    Fuse: 2 x 30A
    Dimensions: 15.12" x 12.31" x 2.4" (38.41cm x 31.3cm x 6cm)
    http://ampguts.realmofexcursion.com/...n_outside1.jpg
    Aug 2007
    pero ung coax ko po ba hindi ba masunog pg jbl 75.4 ang magdrive? ano ba nominal power?RMS din ba ito? kasi nakalagay 280watt maxx 50 nominal power.
    so to power my coax is i need 50rms sa amp kasi nakalagay 50 nominal power tama ba po?? eh diba 104W ang per ch ng jbl 75.4 dba sobra yun?
    Aug 2007
    wicked_jester;937515]pero ung coax ko po ba hindi ba masunog pg jbl 75.4 ang magdrive? ano ba nominal power?RMS din ba ito? kasi nakalagay 280watt maxx 50 nominal power.
Is it necessary to have two amplifiers or just one???
