Results 1 to 10 of 25
Tsikot Member Rank 3
- Nov 2002
- 1,763
May 5th, 2008 10:38 PM #1hello mga audio/video gurus!
i got an 8" lcd tv with tuner from abroad. it receives local vhf signals (though medyo malabo at chan 7 lang malinaw) but it can only get the video. di nya makuha ang audio. static lang. i've tried changing the audio settings na nasa manual (something like 6.0, 5.5, 6.5, etc) pero wala pa rin. pano kaya maayos to? may paraan ba na pwedeng mabago yung frequency nya to receive local channels' audio?
TIA
May 5th, 2008 11:05 PM #2
just check the settings on your a/v unit. i had the same problem when i had my installed in banawe, i just played with all the settings and not only the audio setting, but more on the tv tuner settings. my problem before was no reception, afterwards i got reception but no audio, then after that audio but no reception or the color sucks. but all will be fine as long as you check the settings. as in all the settings.
hope maging okay. i dont have my a/v manual with me, its in the car, so I dont know exactly which setting it should be.
- Nov 2002
- 1,763
May 6th, 2008 02:11 PM #3I see. thanks. sige, try ko uli kalikutin lahat. hopefully maayos. although pinatingin na namin sa 2 electronics shop and suggestion nila is dalhin sa quiapo or gh para ma-hack sya.
June 25th, 2008 01:52 AM #4
sir.. i have the same problem.. from abroad din po lcd ko..
let me know po ha sir.. pano mo nasolve problem mo.
maganda naman reception.. malinaw.. but walang boses..
June 25th, 2008 02:13 AM #5
Di kaya the audio is routed via FM? Ganun kse yung sa TV ng bro ko sa car nya eh.
June 25th, 2008 05:00 AM #6
Pa-update na rin ako. Same problem with my TV. Malinaw yung reception pero walang audio. Sabi ng electrician posibleng sa cable daw ng antenna 'to, refuse to believe it though.
June 25th, 2008 06:50 AM #7
What country did you bought your gear?
If you bought your gear in U.S you dont have any problem since we are using the same T.V standard NTSC (National Television system committee). Most european T.V are using PAL and thier difference is in audio carrier 6.0 for PAL-I and 5.5 for PAL-B.
* coiter:
You have said that audio setting in your LCD are 5.5, 6.0 meaning they are only works on PAL(Phase Alternating Line) with the differences the audio carrier frequency and channel bandwith in the Philippines since they using NTSC. Find a good T.V technician maybe he can adjusted on it since there are plenty audio converters available maybe around 1 hundred pesos(well, not really sure the price, Im just want to make you feel comportable this problem of yours) and channel problem is even less significant.
Next time buying a gear visit this site on which country should avoid buying stuff that will not work in Phils.
NTSC, PAL & SECAM TELEVISION STANDARDS
PAL B/G CHART. PAL D/K CHART. PAL D/K OIRT. PAL B/H CHART. PAL M/N CHART. PAL I CHART ... NTSC, PAL & SECAM TELEVISION STANDARDS. COUNTRY. VHF. UHF. SYSTEM ...
www.mastervideo.com/2111palsecam.htm - Cached
- Nov 2002
- 1,763
June 25th, 2008 08:30 AM #8v6dreamer,
dubai ko pinabili. yun din sabi ng mga nakausap kong technician. wag na raw magpabili sa ibang bansa. natempt lang ako kasi sobrang mura dun. sa ngayon monitor na lang sya for dvd player.
batang_raon14 and AC,
so far wala pa kong solution. yun nga, naging monitor na lang talaga sya. sayang. pero may mga nakita ako sa gh na mga tv signal recievers. try kong itest dun.
anyway, ang nakakaasar, kahit sa cable tv ayaw. may picture din pero walang sound. ibig sabihin ba nito e may frequency din ang cable tv? kakainis lang talaga. sayang pera. hehe
June 25th, 2008 09:24 AM #9
Even in cable it wouldnt make no difference. Phils. is NTSC and your system is PAL-B and G (Saudi Arabia), that built-in receiver is for one variant wont receive the sound of the others.
Kung may kakilala kang taga malaysia ibinta mo na dahil pwede sa kanila yan.
June 25th, 2008 11:55 AM #10
Ford Bronco Outerbanks Sasquatch ... Php4.998M ... ...
Land Cruiser 250
