Results 1 to 2 of 2
- Feb 2008
- 17
February 4th, 2009 07:33 PM #1gud day mga sir!!! help naman po sa amp ko, USAUDIO po brand nya, kulay blue, recently tinanggal sa oto kasi nag pa repaint ako nung ikakabit ko na, nka protect na sya, hindi na nawawala yung protection nya, bka meron kayo alam na magaling na gumagawa ng amp, and how much kaya aabutin? estimate lang mga sir!!! thanks in advance
February 5th, 2009 03:22 AM #2
Try disconnecting the RCA a and subs from the amp. If it still goes in to protect, it needs to rewired correctly including the ground wire.
If it powers ok, by process of elimination connect one at a time between "power ups" each sub and each RCA and see when the protect mode comes on, when it does, there's your problem. You must disconnect the battery while doing this to prevent shortage on the amp.
in my opinion, the more effective deterrent against car theft, is the visible deterrent. if the...
