Results 1 to 2 of 2
    gud day mga sir!!! help naman po sa amp ko, USAUDIO po brand nya, kulay blue, recently tinanggal sa oto kasi nag pa repaint ako nung ikakabit ko na, nka protect na sya, hindi na nawawala yung protection nya, bka meron kayo alam na magaling na gumagawa ng amp, and how much kaya aabutin? estimate lang mga sir!!! thanks in advance
    May 2007
    Try disconnecting the RCA a and subs from the amp. If it still goes in to protect, it needs to rewired correctly including the ground wire.
    If it powers ok, by process of elimination connect one at a time between "power ups" each sub and each RCA and see when the protect mode comes on, when it does, there's your problem. You must disconnect the battery while doing this to prevent shortage on the amp.
help naman on my amp USAUDIO CLASS D MONo AMP
