Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 139
    mga dudes, tanong ko lang kung ano magandang set-up ng sounds para sa EK na Civic. la kasi talaga akong kaalam-alam sa audio e. :oops: kung budget naman pag-uusapan e lets say na lang na sky is the limit chka budget set-up para fair. :wink:
    SQ ba or SPL setup?
    kung sky is the limit eh gawin nating SQ at SPL .
    HU - ALPINE 7995
    AMPS - JL AUDIO 300/4
    MIDS - JL AUDIO VR's
    SEPS - JL AUDIO XR's
    AMPS - JL AUDIO 500/1
    SUBS - JL AUDIO 10" W7 ( 1 )
    PROCESSOR - AUDIO CONTROL
    all targa set up...less than 15k all in all....v12/fenton amp.
    Sep 2005
    Pre, magkano let say:
    4 speakers
    1 amp 200/4
    1 amp 300/1
    1 sub 300w
    be reminded people that you need not spend too much on your audio set-up not unless you plan to beat the world record......:D
    the trick is.....you know how to sound level match your set-up....all balanced......clarity, bass.......and not too much on the pocket....
    Quote Originally Posted by N3IL53N
    101% agree with sir nielsen....
    you really dont have to spend so much for it to sound good...
    go macrom!
    ano po ba yung SQ chka SPL? :?:
    SQ= sound quality
    SPL= sound pressure level
    so....which one do you prefer?
    Quote Originally Posted by Glenn10
    Totally agree with Glenn and Neilsen. IMO the challenge is to have a great sounding system at the lowest possible cost. 8) 8)
    Aug 2005
    Quote Originally Posted by Leon275
    so what is the lowest possible cost of having a great sound system?
    Feb 2014
    Kenwood amplifier KAC-HQR8400
    Maximum Power Output720W
    CEA Spec.
    60Watts x 4 at 4 Ohms and 1%THD+N
    85dBA (Reference 1Watt into 4 Ohms)
    Rated Power
    60WattsRMS x 4ch at 4 Ohms
    90WattsRMS x 4ch at 2 Ohms
    60WattsRMS x 2ch + 180Watts RMS x 1ch at 4 Ohms
    General Features
    Variable Low Pass Filter (50-200[Hz], -12dB/oct)
    Variable High Pass Filter (50-200[Hz], -12dB/oct)
    Bass Boost (40[Hz], +18dB) only Bch
    Size: W 330mm x H 55mm x D 215mm
    pa help Sa Setup ng Sounds Ko ano magandang combination na speaker para sa Kenwood Amplifier ko gusto ko ung maganda ung bass advance tnx sir/mam
    Apr 2012
    mga sir, patulong naman sa sound setup. I have a 2004 BMW 318 and naka stock na sound system siya currently.
    nagpa quote ako sa mickey's and below yung nirecommend kanina:
    Infinity Kappa 5" - ~9k
    Sonus Ecstatic ~13k / Rockford ~20k
    Alpine 9887 (slightly used) ~10.5k
    Sub focal/morel 10" ~8-9k
    Labor ~8.5k
    All prices are just estimates and pwede pang babaan.. it was just a 15-minute chat nung dumaan ako kanina.
    What do you think guys? Ano bang recommended na setup?
    mejo trip ko yung alternative/house music.. and preferrably mejo bumabayo sana yung sounds.
    thanks gurus!
    Aug 2010
    You failed to ask how much Mickey charges sa tuning niya.. you won't take advantage of the 9887 unless you do.
    Second is that you can't lower the prices of products by much since it's regulated by the distributor mismo. If you want to start haggling, doon ka sa labor and services ;)
    I'll go hit you back a longer reply later.
    Aug 2010
    Quote Originally Posted by Det7 View Post
    Labor ~8.5k
    thanks gurus!
    You're off to a good start. First thing you might want to do is head to Kotseaudioclub.com's forums and start reading. Just take maybe 3 days to back read and try to absorb as much knowledge as you can.
    1. I'm not fickle on what your speakers are -- it's hard to get 5" speakers as most speakers are manufactured on a 6.5" diameter basis. Give Mickey your budget, ask what are your options, then choose among those.
    2. The Alpine 9887 is highly recommended. Your next option will be the newer Pioneer 80PRS which retails at 16,000php SRP.. sadly, since it's still relatively new, secondhand prices are still fairly high. You can sometimes spot secondhand CDA-9887s at KAC's ICE selling section and going price is at 7,000php to 10,000php.
    3. For the subwoofer, truthfully.. I'm not much of a subwoofer guy. Subwoofer performance is highly dependent on enclosure. You don't pick a subwoofer then pick your enclosure to fit your needs.. it's actually the opposite way around. Mickey's preference will probably be the Focal Performance subwoofer or the Morel Primo -- both are very good subwoofers (I prefer the Morel in this case) on a sealed box.
    3.1. If you can go for 12", go for a twelve over a ten. Reason for this? More surface area = more efficient at moving air = more bass.
    3.2 For your budget, personally I'll lower the subwoofer's budget. If you want to go for something lower but not too low, I'll vote for a JBL GTO1214 subwoofer. That should free up around 5,000php from your budget for other allocations.
    4. Your amplifier will depend on how Mickey plans on wiring your system. From the looks of it, he'll probably tap the 9887's built-in amplifier for the tweeters, run the midbass on two of the amplifier's channel (4-channel amplifier), and bridge the other two for the subwoofer.
    4.1 You will run full-active in your system. Because if you don't, you're not utilizing your CDA-9887's processing capabilities.
    5. Try to note of all other miscellaneous expenses such as subwoofer enclosure costs. Then you also have to budget for wiring costs (again, ask for your options at your budget), labor, woodworks, and lastly tuning costs.
    hinde rin mga kosa , yes meron din na may quality sa gawa pero may limitations ito and not ka level sa performance . Yes mura nga pero hanggang dun lang yung binayaran mo , kung ano ang capable ng euipment whatever it is . Sa car audio hinde sila parang damit talagang pangalan lang ang binayaran mo but sa car audio binayaran mo ang kind of materials used and sa quality nito . like the local subs let's sayTarga , not sure kung locally made ito pero meron ba silang subs na naka titanium cone? wala di ba ngayon yung subs na may titanium cone sywmpre mahal kasi malalaman mo naman talaga ang difference ng dalawa , ngayon itong scenario na ito example " nasa set up ang pag attain sa gusto mong klase na sound " ngayon kung ang
    mga " mura " na tama ang set up ok siya but yung " mahal " na tama din ang set up malaki ang pinag iba ryt ? Ryt , nasa tao na lang talaga yan kung paano siya kontento sa capabilities ng system niya .you get what you pay for .
    what is the defining difference in sq and spl?? (in terms of sound and feel?)
    la talaga ako alam sa audio setup... hindi ako hard-core sound dude, pero gusto ko naman may pleasure yung listening experience ko. sabi sa akin 3-way speakers lang ok na?
    sir logbook,
    ganito po yung pagka-intindi ko diyan sa SQ and SPL. if you go to a disco house and listen to the sound, that is SPL. the focus of the sound is more on the bass. if you go to a jazz concert, that is SQ. you can hear the clarity of the music, and differentiate the sound produced by each instrument. of course balance lahat ng tunog dito.
    some people like systems that has both SQ and SPL... some people calls it SQL.
    actually, may nagsabi rin sa akin na okay na yung 2-way. i suggest that you try to listen to different setup, before you decide your own. just make sure na narinig mo muna yung bibilhin mong gamit. lagi kasi nasa huli ang pagsisi.
    logbook,
    3 way seps are ok but if you can achieve the listening experience you want with 2 ways, then you're better off. If you decide on 3 way seps, you have to consider the space they're going to occupy. You may need to bore more holes on your doors to accomodate the drivers, have custom door panels made for imaging / positioning the speakers, or even make use of kick-pods(& i have nothing against them :wink: ). If you go for the 2 way seps, you might not even need to sacrifice your door's stock grill. It all depends on you on how simple or complex your system will be.
    I'm always amazed by peeps with simple audio setups but with sounds that are very rich and balanced. A agree with the guys above on auditioning different setups before you decide. At least by doing that, you would have a better idea on what system you want for your ride. :mrgreen:
car audio set-up
