Results 1 to 10 of 39
April 29th, 2008 02:31 PM #1
stock radio honda..fujitsu ten ata toh...30watts...
going to buy pioneer hu na 50watts...
big difference ba? or ndi?
iniisip ko kasi if i'm going to buy speakers agad together w/ the new headunit.
or orig speakers muna w/ the new unit.
April 29th, 2008 02:46 PM #2
Mas malakas lang ng konti. less than 3 db. Every 3 db means that the power is doubled (or halfed).
I am using stock HU (40W x 4 channels), I have upgraded my speakers first. Sulit naman. Gumanda ang quality at mas malakas. Kahit na wala akong sub, may konting boom na.
Kung limited budget ka, you can upgrade the speakers first din. 1 pair at a time.
Let us say, you upgraded your HU but stock speakers, di pa rin gaganda ang sound set up mo. Either speakers first, or speakers and HU.
April 29th, 2008 02:59 PM #3
salamat ng sobra sir.
mapilitan unahin ang head unit, para sa aux in kasi. d ako kuntento sa fm modulator. ndi cd quality yung tunog eh. sayang ang ipod.
thanks again...
April 29th, 2008 03:40 PM #4
if you say difference? what are you expecting? more ooomph? better sound quality? kasi kung more ooomhp, medyo wala masyadong difference yan. you can only put that up to Volume Level 30, kung hindi, basag na rin ang tunog nyan if you are using stock speakers.
for sound quality, it would depend on the speakers used, although may minimal difference din ang stock HU and aftermarket HUs.
kung ako ikaw? i will initially invest in good speakers muna and take it from there based on the sound output that i want. pwedeng you take the:
SQ mode: separates/excellent 6 x 9/tweets or
Power mode: amps/subs/tweets
initially, kaya yan ng stock HU mo. tsaka ka na lang bumili ng aftermarket HU kung hindi ka pa kuntento.
imho.
April 29th, 2008 04:14 PM #6
When I upgraded mg stock speakers, I have checked the HU manual kung ano ang impedance na kaya nito at kung ilan ang power out. 4 to 6 ohms ang stock HU ko at 40W per channel.
Ibig sabihin nito ng I can use any speaker na 4 or 8 Ohms na at least 40W rms ang rating.
If eventually, gusto mo na gumamit ng amp, better use higher wattage speakers now kahit HU powered muna. Para you do not have to replace the speakers eventually.
Take a look at the RMS ratings not the peak power. misleading ang peak power.
Better kung maririnig mo na gumagana ang selection mo ng speakers bago ka bumili = audition.
Speakers have a sensitivity rating. If a speaker has a sensitivity rating of 89 dbm, while another has a rating of 92dbm, the 92 dbm will be louder. Theoretically 2 times (3db difference kasi) louder ang 92dbm. Assuming same impedance, wattage, size, 2way or 3-way.
BTW, I am now using bang-for-the-buck JBL.Last edited by meledson; April 29th, 2008 at 04:17 PM.
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 29th, 2008 04:24 PM #7Just remember that most HU over state their true output power. They may claim 50 watts RMS even if it only pumps out 12 watts RMS.
April 29th, 2008 04:40 PM #8
that's good user...
how much sir ang jbl niyo?
how much do jbl seps cost nowadays?
April 29th, 2008 04:53 PM #9
the main difference ng stock hu and aftermarket is the 50wX4 mosfet. yun ang kailangan mo for the SQ that your looking for. also the stock has the wired out while the aftermarket has the aux for sub and speakers.
yes, the SQ will improve if you change the speakers pero its not that much if you did not change the HU. the speakers always depend on the quality of the driver (HU) and how it is connected. the aux will give more clarity rather than the splice and twist.
April 29th, 2008 05:17 PM #10
mukhang no choice...pag ipunan na lang..para one time big time nalang ..
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
