Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    #21
    TheTS is looking at either upgrading the stock HU or stock speakers on a limited budget. IMHO, to get better sound quality compared to stock is to upgrade the speakers first. If budget is very limited, a pair at a time. I ws suggesting to upgrade the rear ovals first, then the front door speakers.
    Parang wala pa akong nabasa about a sub from the TS.
    yes, budget yung setup na gusto ng TS, thats why i would recommend tha the HU first before anything else. the driver (HU) will make or break your SQ lalo na kung walang amp.
    kaya this is what ive said :
    if you can get the seps and HU all together, then id say go for that muna. kahit full setup ka na (amp subs seps HU crossover) hindi mo kailangan ng quality rear coax. pero if your just going to stop with HU seps and rear.. then definitely, go for all the speakers.
    May 2007
    #22
    Quote Originally Posted by winferrer View Post
    stock radio honda..fujitsu ten ata toh...30watts...
    going to buy pioneer hu na 50watts...
    big difference ba? or ndi?
    iniisip ko kasi if i'm going to buy speakers agad together w/ the new headunit.
    or orig speakers muna w/ the new unit.
    You did asked a question and too many responsed w/ diff. opinion. Now, where did we go from here? If you really want to go beyond basic factory replacement observe a few common sense and youll sidestep potential mistake. Dont be discourage no matter what kind of project you're planning, decide what kind of music that is best suit in your lifestyle and how far you want to go before you begin.
    For me, I would go w/ the H.U first with at least two pre-amp output if outboard amplifier's is on the list and also the functionality like USB connection, built-in iPod controls and so on for future expansion(well,you dont have to go all this). You dont have to get all the gear in one time.... upgrade one step at a time your dream system all the way to nirvana. Again plan ahead, so all the components you buy are compatible w/ your ultimate goal.
    Your question about watts.
    If they said watts its the peak power not RMS.
    #23
    Agree with your view bro.
    Again, if you want to improve the sound quality of your car stereo and you are on a limited budget,- change your HU first. Your idea from a 30W to a 50W HU should be a good move. The speakers are almost always built the same. Nothing special with them nowadays. And even if you change them, how can you expect better sound quality if your source(HU) is still wanting or inadequate? But with the HU,- now there's the difference. I suggest you get the one with a bass boost,- although this is pretty much the standard nowadays. Your stock speakers can handle it.
    I know that because I've been doing this for all of our vehicles past and present and there's definitely a significant difference in sound quality.
    5909:burn:
    Aug 2005
    #24
    Sa Avanza ko, inuna ko ang speakers. nakita ko ang stock speaker. paper cone lang. walang tweeter. 1-way lang. Ng napalitan to JBL, may boom na ako (pero syempre, iba pa rin ang boooooom booooooom boooooom ng sub) at high frequencies. Stock HU pa rin. It was cheaper for me to replace the speaker than to replace the HU first.
    IMHO, kahit gaano kaganda ang HU kung kaawa awa naman ang speakers .....
    I might go for a sub first than replaceing the stock HU.
    #25
    ^^^ Bro,- maybe one-off?
    5909:burn:
    Jun 2006
    #26
    5909:burn:
    I agree with the HU making the most impact on a limited budget.
    However, speakers are not all the same. Far from it. The cheap speakers that normally come standard in cars will sound pretty much the same, but upgrading them to even cheap Targas will improve sound quality a lot. More so with high end speakers like Focal, Morels etc... Of course the better speakers will need quality amps to really make them sing.
    Personally, I'll upgrade the HU 1st. Then use any money left to get better speakers. Remember the speakers are the only part that you can actually hear. I'll go as far as suggesting to put the most money on the front speakers. For budget meal systems, Targa, JBL, Crystal and Infinity give good return for you money.
    Amps will be optional for now, since you are on a budget. If you can, get a 4 channel amp from Fenton or a fake V12. They will do the job. Why a 4channel amp? You can power both front and rear speakers. Then if you get a sub, just move your rear fill to the HU and bridge channels 3 and 4 to power your sub.
    Dec 2007
    #27
    hhhmmm how about MP3 player and headphones?
    m sure mas ok yan..pag tight budget...joke..lang...
    mas ok ipon ka muna then search sa forums tapos buy na...
    #28
    Quote Originally Posted by v6dreamer View Post
    naku, pre amp pala tawag dun... old school na ata ngturo ng sound setup sakin kaya tawag niya pa din aux out...
    anyway, yes this is true, always start with the HU first before anything else. you dont have to do it all in one time. if on a budgeted setup, just have the idea of what you wnat to achieve in the end. kung full SQ, then HU - seps - subs and amp sabay plus the wiring (eto yung pinakamahal na step)
    then for better SQ lang without the amp ang target, HU -- seps -- rear. pero warning ko lang is baka mabitin ka sa sounds then ull end up buying the 3rd setup of subs and amp... sayang yung nilagay mo na rear.
    Quote Originally Posted by userfriendly View Post
    precisely!
    pero heres the catch, if your just using stock rear, do not power it with the amp... it might not be able to handle the power. i might be wrong coz i never really recommend doing this.
    Jan 2008
    #29
    agree ako na unahin mo yung HU. no matter how good your speakers are they will still be dependent on how much power your HU will provide (unless you have an amp w/c is out of the question for now).
    advice ko... masaya ka na ba sa bibilhin mong HU? ok na ba ang features sa iyo (radio & CD lang ba? baka gusto mo rin ng mp3, wma, usb, etc?)?
    make sure ok na yung feature para hindi ka na magbago in the near future. kung medyo mahal yung gusto mo, save up for it. tiis muna
    Dec 2007
    #30
    I would personally attest to the HU upgrade improving your system's sound.
    Until now I'm still running stock speakers on my Jazz. When I replaced the stock Kenwood HU for my present Pioneer unit, the sound of the speakers changed dramatically.
    I'm not very picky with sound staging or other SQ terms, so I noticed the sound image is pretty low due to the location of the speakers (at the footwells). But provided I don't crank up the bass and volume so high as to induce rattles, the stock Jazz speakers actually sound fairly decent and clear since the hookup to the Pioneer HU.
    Aug 2007
    #31
    magkano ba ang budget ng TS? mahirap mag suggest kung hindi ko alam ang budget mo sir.. let say kung may 10k ka pwede mo na unahin ang head unit and seps, un na lang muna.. saka ka na mag sub kasi mas madugo yun..
    Aug 2005
    #32
    Alin honda ang car mo?
    Aug 2003
    #33
    yup...not a fanatic w/ subs...
    previous car had a sub....and the head unit then had a setting to turn off the subs or lessen it..lage lang nakahina sya....
    now kc, w/ the new car, eh monthly pa lang nito..kaya sinisingit ko lang ang sound setup. hehee...
    naisip ko kasi, the problem i'm going to have is pag nag seps ako...baka walang ka bass bass naman ang tunog. kc pangit stock speakers ng city idsi, lalo na ung sa rear. baka ang pangit ng timpla.
    Aug 2007
    #34
    yun nga lang mahina ang bass o bayo kasi yung seps puro boses talaga.. di bale madadala na naman yan ng head unit mo in that case, magpatugtog ka na lang ng mga acoustics..
    Aug 2005
    #35
    Sa 2007 jazz idsi ng boss ko, the HU can play MP3 CDs. Sound quality is OK naman. Not much highs nor lows. The audio sound quality of the Jazz is a lot better than my avanza before. Now that I have upgraded my speakers, my biased opinion is that my avanza's audio, now sounds bettter :D. BTW, I still have no sub. Pag iipunan pa.
    IMHO, we should get the opinion of other car owners with the same vehicle, what they did to their city idsi in terms of the audio specs.
    Aug 2003
    #36
    avanza ng mom ko..oh nga...d ganon ka ganda, as compared to revo namen dati. ganda ng sounds ng sportrunner kahet stock. as in maganda.
    stock ng idsi city. d talaga maganda for me.
    salamat mga information mga sir.
    mukhang another option for me, is 2nd hand. lahat. para sabay sabay. hehe..
    #37
    in that case, the rear coax and seps with HU is the sound for you...
    in case your going second hand, just be careful na baka damaged goods yung makuha mo...
    theres a way to test:
    the easy way: press down on the edges of the speaker and there shouldent be a sound while doing this
    the hard way: connect it to wires then see if its clear (no static or what ever noise other than the music)
    good luck sir!
    Dec 2007
    #38
    Suggest ko unahin mo pagpalit ng HU...malaki ang iginanda ng tunog ng stock speakers ng City sa pagpalit lang ng HU ;) I had a 1999 City before, all stock yung sound system...ang laki ng diprensya ng stock speakers noon sa Jazz ko. Yun talaga, panget!
    Ngayon kung nagawa mo na iyon tapos di ka pa rin satisfied, mag-seps ka na. Suggestion ko sa seps, hanap ka ng medyo mababang mounting depth kung ayaw mong magputol ng bakal sa pintuan. 64mm or lower. May seps naman na ganyan, good luck bro
    Feb 2004
    #39
    i fi were the TS, i would get a decent HU first.
big difference? 30watt and 50watt headunit
