Originally Posted by
v6dreamer
Get a full range speaker's 61/2 on the front 6x9 on the rear. Choose an speaker's w/ high Sensitivity (dB)....ex 94 on the sensitivity (dB) rating rating it will play louder on your stock H.U w/o external amplifier, this is ideal for your stock.
Also make sure that the speaker's RMS power range (watts) start at 2 RMS, this is "important" if youre not using an amplifier using only the stock H.U or distortion are present if you dont follow this, you are not going to happy the result.
Example of speakers power range:
2-25 RMS power range(watts)
2-30
2-35
2-40
2-45
2-50 and so on, will do for your stock H.U.
If the speakers RMS power range (watts)start at:
4-30 RMS power range(watts)
4-35
4-40
4-45
4-50 and so on or,
6 and so on
8 and so on
10 and so on, do not use this.
Your H.U are too weak to pushed this speaker's. You'll need an amplifier to run this speaker's. Pay especially close attention to this specification to avoid common mistake's.
Good luck!
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
