Results 2,821 to 2,830 of 3070
May 3rd, 2018 11:40 AM #2821
Usual na nakaka sira ng speakers ay ang underpowered amp trying to push the speakers to play loud music or using gain knob as volume control. Pag ganyan, clipped signal na ang lalabas sa amp instead of proper sine wave. Kaya ang nasusunog ang coil dahil mahaba ang peak ng clipped signal compare sa sine wave at ang coil ng speakers ay hindi designed para dyan to stay that long at a certain position. it has to move back and forth para din sa cooling. Pag tumagal sa isang position at pa ulit ulit itong mangyari iinit at iinit ang coil. Ang result, sunog.
- May 2013
- 12
May 5th, 2018 11:50 AM #2822Hi im new to all this audio stuff so im looking for some help.
I drive a 2017 vios J it doesnt have rear speakers as stock so I had some sony coaxials put in. Now im thinking of adding a sub or getting component speakers up front. Would it be worth it? or should i invest in a better headunit first? the stock headunit has one pair of rca so i think it would be fine if i got a sub.
- Jul 2009
- 3,604
May 5th, 2018 12:23 PM #2823For starters, I think:
1. A good 10-15k set of component front speakers/tweeters
2. Deadening - ~5k
3. New Head unit
Unless you play your music very loud, I think most people will be happy with #1 and #2 palang.
If you're past #3, look into adding an amplifier and a sub.
Personal disclosure, hanggang #1 lang ako usually; #3 when the stock unit dies.
May 5th, 2018 04:34 PM #2824
Most if not all loves that extra low frequency oomph so yeah.
Follow mda's advice, just get the highest sensitivity that you can afford on your component speakers if HU lang gamit mo. And if kulang pa then get an amp for your component speakers and if kulang pa rin add a sub and mono amp.
- 54,252
May 5th, 2018 08:07 PM #2825there may be a geometric relation between increase in sound quality and increase in price.
good luck, sir.
don't be bitten by the audio bug. "it has no cure."
May 5th, 2018 08:25 PM #2826
I remember our CR-V 98, the speakers were bad already and I couldn't stand the quality of music since I'm always driving for 160 km one way. I finally decided to upgrade which cost me 50,000 for DLS setup by that time.
As it was installed, the music won't play properly. I was informed that the old head unit is no longer compatibility with the amplifier and so on and so forth. I had no choice but to buy another head unit that costed me an additional 25,000. My wife was giving me the "stare". I just smiled back stroked her hair...
If I went to some shops "without name", I don't think it would have costed me like this. However, I don't know what to look for and I'm not sure if the brand DLS is original or not so I opted for this shop in Makati.
Why is it that I didn't know about this forum before?
- Jul 2009
- 3,604
May 5th, 2018 08:33 PM #2827
May 5th, 2018 08:43 PM #2828
The setup for DLS is already posted in their site for 50,000. I already knew the price when I went there. What I wasn't aware of was the compatibility of the head unit. There were other brands but I wanted to maintain the original brand so I opted for Kenwood. Pioneer is much cheaper and I think there shouldn't be any difference for someone like me who knows nothing about this kind of setup.
Surely, the price of the head unit should be much cheaper to other shops but I don't have much time to look for it and I wanted to finish the job so it was more like "I don't have much choice".
EDIT: You should check Mickey's where according to that guy I met said he spent about 350,000 for the sound setup.
- May 2013
- 12
May 6th, 2018 07:12 PM #2829
- Jul 2009
- 3,604
May 6th, 2018 07:34 PM #2830
Just like the Rehab of Boracay. A lot of people hated it, loss of jobs , etc, etc, etc. Look at...
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
