Results 2,851 to 2,860 of 3070
August 9th, 2018 01:10 PM #2851
August 9th, 2018 01:36 PM #2852
Based on the feedback here my first choice will be Morel. I like it warm. Haven't auditioned any brand yet though so I'm open to other options. I won't go above 20k for seps kasi baka sayang lang ang capabilities ng speakers sa use case ko.
Parang leaning towards option 2 din ako. Less invasive and baka masaya na ako sa simple speaker upgrade and deadening lang. Ayoko kasi maglagay ng amp under the front seats so if they put it in the trunk may woodworks pa kelangan to install it somewhere that won't affect the luggage space much. Will still depend kung anong speaker ang kayang i-drive with the stock HU. Will definitely listen to the installer's advice when the time comes.Last edited by JohnM; August 9th, 2018 at 01:40 PM.
August 9th, 2018 03:22 PM #2853
with your budget now, option 2 ka nga bro. check out other popular brands like focal, helix, dls and others. installed focal sa car and van ko, bewith sa suv, all are entry level seps lang yet the sound improved a lot in terms of tonality. i'm not into hardcore audio set-up so hindi ako too clinical whether warm or bright, o kaya yung mga imaging, soundstage, etc. if your music source is good at maayos pag-tune ng installer sa speakers then ok lalabas at magiging mas enjoy makinig while driving. try mo muna walang amp at subwoofer, kapag nakulangan ka sa ingay at bass saka ka na lang magdagdag.
August 9th, 2018 03:40 PM #2854
Yep, DLS is really good. Even their budget Reference series are quite good. My old Exalta before had DLS speakers and amplifier in a 2-way active setup.
If you are leaning towards warm-sounding speakers, I would suggest DLS. Morel also had that warm-sounding speakers. These two brands though have speakers that need a bit more power to give them that oomph so I suggest you get a decent amp to power the speakers properly. DLS, Focal, Genesis, Audison, Helix, and JL are a few of the good brands for amplifiers. You can also use some of those newer, more compact class D amps which could easily fit under the front seats.
August 9th, 2018 06:48 PM #2855
Thanks for the inputs guys. At least may direction na ang plano ko
Will update kung natuloy. Most probably kay Micky ako papagawa as they're the most convenient. Medyo malayo na si Jonz sakin and allergic ako sa Ortigas ExtensionAny other recommended shops in the Taguig/Makati area?
August 9th, 2018 06:52 PM #2856
August 9th, 2018 07:00 PM #2857
I prefer yung mga shops na specialized sa car audio kaya medyo low on the list si Autoline even if they're nearer.
IIRC Mickey did a Mazda 3 din a few years ago. At least kampante akong alam nila ang ins and outs ng oto. Integrated kasi ang HU ng Mazda iba ang setup compared to the usual DIN HUs.
August 9th, 2018 07:15 PM #2858
- Apr 2006
- 419
August 11th, 2018 10:20 PM #2859i started at straight jbl setup - seps + amp, then after few months added a 12” subs on a ported box with mono amp.
then it evolved to several brands...and ended up to straight RE setup.
August 12th, 2018 05:48 PM #2860
