Results 2,941 to 2,950 of 3070
March 6th, 2019 11:44 AM #2941
March 6th, 2019 11:52 AM #2942
Wow included pa flooring sa 5k sobra sulit na! Madali lang ba lagyan acoustipad yung flooring?
Sobrang takimik nung kotse niyan lalo na kapag wala kalampag. Hehehe
Sa next project pwede ka na din roofing para hindi mo na maririnig yung ulan sa bubong
CTK is better kasi lighter vs acoustipad. Also yung materials used is different.
Pero personally i'll stick with acoustipad kung flooring lang. Then sa door, outer is CTK then acoustipad yung pinaka-door wall mismo.
March 6th, 2019 12:13 PM #2943
March 6th, 2019 12:36 PM #2944
Mag lessen daw kasi road noise kapag nilagyan deadening sa flooring.
Insulation actually pwede din in between ng flooring tska deadening sheet. Kakapal lang kapag inapakan mo
Pero 5k sa flooring and double wall sulit na din sa totoo lang. Nakakangawit kasi yung parang roller na ginagamit. hehe
March 6th, 2019 12:45 PM #2945
^heat gun ginamit sakin bro. baka palgyan ko ulit next car ko, pero ang laki din ng weight penalty eh
- Jan 2008
- 4,726
March 6th, 2019 01:10 PM #2946
March 6th, 2019 02:22 PM #2947
- Sep 2011
- 16
March 7th, 2019 02:33 AM #2948Hello mga Masters,
My ride is a Suzuki Vitara GLX 2018 model with deadening installed on four doors and has the following setup,
HU: Stock Allwinner Brand with 10” screen (CPU:1.6GHz Arm Cortex A7, RAM:1GB, ROM:16GB, OS:Android 6.0.1)
Front: JBL GTO 609C seps
Rear: JBL GTO 629 coax
Amp: Planet Audio Anarchy AC1600.4 (4-channel amp with total rated power of 800W *4ohms)
Sub: Planet Audio PA8W (powered underseat subwoofer with rated power of 800W)
LOC: DS18 V5HL (for the HU kasi walang RCA outputs)
I’m not satisfied kasi on how the tuning was done after all the hardware was installed. Yong ginawa kasi ng installer yong tuning tenga lang kasi ginamit wala man lang maski a simple voltage measurements using a voltmeter to check on the input and output signal levels at different stages. In my novice opinion parang kulang or hindi tama yong pagkagawa sa installer and wanted to redone it properly in a meticulous manner in my own limited way at no additional cost for optimum SQ. Although newbie lang ako sa car audio, Im a willing learner and could learn fast basta pasensyoso lang yong mag guide sa akin. Can you guys help me with this, please? How do I start with the above given setup?
Thanks in advance.
March 7th, 2019 02:56 PM #2949
Nothing wrong if tuning was done by ear to be honest. Almost all usually starts with the equipment then tune ulit by ear pero usually minor details nalang.
No additional cost means bringing it back to the installer and telling him/her the problem. Wag ka muna papayag na pabilhin ka ng ibang items.
2nd option is bringing it to another installer for checking. Pero usually eto at cost na kasi gagamitin mo oras niya.
Where's your location?
March 7th, 2019 03:00 PM #2950
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
