Quote Originally Posted by artsky View Post
Thanks boss. Medyo may idea lang ng kaunti sa audio hehe. Naisip ko lang kasi since walang tweeters ito baka puro bass na lang narinig ko hehe. I have also limited the bass to the stock speakers to rapidly roll off below 50Hz ata since hindi kinakaya at distorted na ang sound pag malakas ang bass ng song.
Mas ok ba amplify pa yung fronts even if the HU says it has "50watts" of output power per channel ata? Will I get a cleaner sounding system that way?
Yes boss, mas ok i-amplify yung front. Same system na-try ko na amplfied and not, malaki difference lalo na if you are playing medyo high yung volume. If you'll read the fine print, it says that up to 50 watts per channel but sa actual, it only produces around 20-25 watts lang.
Cleaner sounding, basta proper installation, correct gains and settings, yes is the answer to your question.
Quote Originally Posted by KaiserRon View Post
Any suggestions for the seperates? Ok lang naman na wag ko na palitan ung rear speakers di ba? Pinalitan din yun ng teac e. Most of the time naman solo or 1 passenger lang e
Sent from my SM-N9208 using Tsikot Forums mobile app
How much is the budget for the seps boss? No need to replace the rear speakers. But kung napalitan na pala talaga, gawin mo nalang full active yung teac front. Then HU powered yung sa rear.
