Results 2,571 to 2,580 of 3070
August 29th, 2017 11:51 AM #2571
August 29th, 2017 10:50 PM #2572
I have pioneer avh, Kinetic ampli, morel seps and jbl subs nakukulangan pa din ako sa sound quality and clarity what do you recommend upgrade ampli or install sound processor or do both?
Sent from my SM-G930F using Tapatalk
August 30th, 2017 04:59 AM #2573
August 30th, 2017 05:06 AM #2574
Try tuning first before spending. If clarity problema baka naka push yung gain ng mataas, which invites more distortion. If the gain is set low and panget pa din clarity, then it's the amp.
Then which AVH model do you have? There are some HUs that can do Network Mode or what we commonly call Full-Active. That is another way that can put more control in your tuning. Mas maganda if you can join one of the EBs of SQ Manila, so our audio gurus can audition your ride and give advice on what's needed to be changed or upgraded.
August 30th, 2017 09:18 AM #2575
- Apr 2007
- 19
August 30th, 2017 01:23 PM #2576
- Jul 2004
- 241
August 31st, 2017 09:19 AM #2577
August 31st, 2017 12:01 PM #2578
September 1st, 2017 03:11 PM #2579
^Got accepted after 3 days i think
- Aug 2017
- 15
September 1st, 2017 08:12 PM #2580sorry for late reply sir, divx 720x404 ang size ng video sir..depende din po kasi sa converter minsan sir mas maganda pag license kasi mamaximize mo ang specs nya even the bit rate for video and audio kaya kahit youtube lang galing mapaganda mo output ng converted files..
Eventually this undetaking has to take place but it is the planning and coordination that is...
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
