Page 102 of 154 FirstFirst ... 252929899100101102103104105106112152 ... LastLast
Results 2,021 to 2,040 of 3070
    Jul 2016
    #2021
    Quote Originally Posted by sientobente View Post
    Yup sir, that is actually the exact model I am referring to. May member po tayo dito yan yung gamit sa isang kotse nya, si Ninjababez. Don't worry about the specs, RF is known to underrate it's numbers. Importante your existing sub would run on 4-ohms so you will be able to bridge 2-channels from the amp to power it. If everything is a go, great! Then ipon nalang for a good set of seps in the future.
    Now leaning on this option.
    Is there a local distributor of RF amps? Also want to check the local pricing... if not that far from amazon price, would rather get one here than waiting for 2 to 3 months.
    Thanks!
    #2022
    Quote Originally Posted by x.mayor View Post
    Thanks!
    Winterpine ata yung official distributor ng Rockford Fosgate. However, it's better to inquire among known car audio shops for the best deals in RF equipment or some other mid-tier brands. Mickey's Auto Sound is one my trusted sources of audio equipment.
    Aug 2010
    #2023
    Quote Originally Posted by benchman View Post
    that would be fine then, it's a 6.5" speaker.
    most HU's built-in amp nowadays have 45~50w rms power output kaya ok na iyan.
    It isn't RMS. Head units just have around 20W of RMS power in them unless you're touting an Alpine with a power pack module installed. Still, 20W is enough for the majority of users.
    Medyo harsh ang highs ng JBL/Infinity. Kinda piercing. Something warmer around that budget is a Hertz DSK or ESK. Or if you would like to add more, my favorite right now at that price is the Flux FS260. Very neutral sounding, easy to power, and adapts well in any kind of music.
    I would say that's not due to brand but because of tweeter material. JBL/Infinity originally used metal domes as their material of choice. This, while technically superior, is extremely harsh sounding if you're using them incorrectly. For the tweet volume, just tone it down. Personally, I'd classify JBL/Infinity as rather neutral.
    This might surprise you but Harman, being a huge audio conglomerate, tries to conform their speakers on what typical listeners like their sound signature to be: high on the bass, neutral on the mids, a gently downward sloping curve sa highs. They have a white paper on that one.
    Re: Recent posts
    1. Is your amplifier power enough?
    Most likely it is. Most people just need 50-75W of RMS power for their fronts really. Unless you're part of the population who listens loudly. Power is exponential it isn't a multiple: 100W of power isn't twice as loud as 50W. Want twice as loud (+10dB) of 50W? Try 500W.
    2. RF is under-rated
    Contrary to popular opinion, this isn't true anymore. It used to be in the past as Rockford was conservative in testing their numbers (ex. testing at 13.8V rather than 14.4V). RF follows CEA figures so it's neither under-rated or over-rated if you compare it to another CEA-certified amp.
    3. Rockford Fosgate
    Winterpine Marketing is the distributor of it. I would recommend you wait for their quarterly sale in their HQ as some goodies can be had for a discount. Would I recommend buying them online? I am neutral. Reason for this is that RF has great quality control and it's unlikely you'll get a lemon. Historically, RF enjoys one of the industry's lowest return/exchange rates as a statement of one of our leading car audio shops. If you just want to check the price, check out Mickey's website. I use it to get SRP pricing too :D
    That's all.
    Feb 2011
    #2024
    ^ Oo nga noh, CEA rated na pala RF ngayon. Used to the old school RFs with their birthsheets exceeding their advertised ratings.
    Regarding JBL/Infinity, I think it is more of their house sound. Even their home audio products sound the same. I believe this has to do more with system matching. Since the main amplifier the Harman group carries is Harman Kardon. For higher-end Harman group products, Mark Levinson amps sounds great with Revel speakers.
    May 2010
    #2025
    Hi, I have a gen 2.5 Santa fe using pioneer avh-2750bt and morel tempo 6.5. Malaki ba improvement if I add an amplifier? I prefer SQ and don't play too loud
    Dec 2007
    #2026
    Quote Originally Posted by trig View Post
    Oo naman bro, lalo when it comes to the loudness of the volume. The morel tempo for one, in my own experience is a speaker that really needs a powerful external amp to bring out it's potential. Even if your not the type who cranks up the volume, powering the morel tempo with an external amp will give you a cleaner more detailed sound compared by simply driving it with the HU.
    Teka, what amplifier do you have in mind?
    May 2010
    #2027
    Quote Originally Posted by markygy View Post
    Thanks for the reply.
    Wala pa sir. Still thinking if I'll add an amp and maybe a removable sealed 10" sealed sub. Maybe around 15-20k budget. Any recommendations?
    Dec 2007
    #2028
    15-20k budget? That's a hefty good budget you have, hehe! If so, try to consider the Rockford Fosgate T400.2 power series amplifier for the morel tempo.
    May 2010
    #2029
    haha no, i was thinking 15-20k for both the amp and subs. If ever I add a sub, i need something small and easy to remove so I can still use my cargo space
    Mar 2005
    #2030
    Yes malaki sir pagbabago if you add an amp. SF2 yung sakin sir and I suggest to deaden yung front doors na din.
    May 2010
    #2031
    Quote Originally Posted by jmpet626 View Post
    yes sir, naka deaden yung front door pero yung basic lang from ACA
    Mar 2005
    #2032
    Nice! Sakanila din ako nagpa deaden kaso di na nila binuksan yung inner metal door shell. Nagdagdag pa ko ng isa pang sheet per door pero DIY na lang. Nag dagdag pa ko sa may inner door shell, pinadaan ko na lang sa speaker hole.
    Yung Custom box ko sir dun ko din pinagawa. Consumes 1/4th of the rear space. Bali 6 seater na lang SF ko which is ok lang naman ako masyado cargo and passengers. Naka quick disconnect plug din if ever i need the space.
    Feb 2011
    #2033
    I agree with Boss Mark, it will definitely give an improvement. In my experience, it pushes out more details. This may mainly be caused by lower THD levels using an external amp rather than using the HU's internal amplification.
    I think a Hertz combo works with that budget. It's the Hertz Deici 10" sub and Hertz HCP Amplifier if I'm not mistaken. Just add a little more for the enclosure and wiring.
    #2034
    mga sir kapag naglagay ako 1 pair ng 6x9 speaker yung nasa box sa trunk maririnig ba sa loob ng kotse yun o bale wala lang ayoko kasi maglagay ng subwoofer kailangan ko yung space .... salamat
    Mar 2013
    #2035
    I placed a focal IS 165 and PS 165 in my kia carnival using the amplification coming from the android headunit. Very satisfied with the sound. Much better than stock. I dont need a subwoofer. They put some sound deadening sheets and foam as well in the doors.
    Wanted to go with the much cheaper pioneer separates but the store was able to sales talk me into getting the focals. I wonder if the sound is much different? Im not an audiophile so if i can save a lot of money, my next project will just go with pioneer or JBL speakers. Or is Focal really much better? Noob question sorry.
    Sent from my SM-N920I using Tapatalk
    #2036
    absolutely yes bro, i can tell that my focal polikevlar 165k sounds a lot better than my mb quart
    Aug 2010
    #2037
    My two cents over it is less exciting over the previous quotes of forumers
    Malaki ba ang improvement? The answer will be..
    No - if you don't play loudly. While there's an improvement because it's "cleaner" (usually referred to as THD%), I wouldn't pony up the moolah as an amplifier will cost as much as your speaker. A more cost-efficient method is to deaden your doors in order for it to rattle less and this gives you a better sound (rattles interfere with the sound frequency by cancelling certain sounds)
    Yes - if you play loudly. Nothing better than good ol' power for playing them loudly.
    Quote Originally Posted by aprilboyidol View Post
    It will depend. Maririnig ba? Well, if it plays full-range, it'll sound muffled (kinda obvious). If you're looking for the bass, the reason why subwoofers can be thrown to the trunk is because bass waves are long and have incredible penetrating power unlike high frequency sounds.
    I actually have this theory that the reason why many people love Focal is because it's more expensive (there's the price bias) and because it's expensive it allows for a bigger magnet (hence higher sensitivity). Which means it'll be louder and cleaner than competing rivals.
    Is the sound much different? It actually is. But is it really much better? I would say no to that.
    Apr 2016
    #2038
    guys need help po. I'm setting up a simple sound system for my 1996 pajero. Binigay sa akin nung friend yung 3 months old niya na Kinetic KD5001 to start off. It has USB and aux-in pero no cd but its ok kasi more on usb naman ako. Ok kaya yung binigay sa akin na Kinetic HU? some say its taiwan pero good quality naman daw
    Aug 2010
    #2039
    Quote Originally Posted by alpharomeo33 View Post
    Then go for it. Meron naman warranty mga yan.
    Dec 2007
    #2040
    Like what was mentioned, muffled ang magiging tunog niya. Hindi ba kaya ilagay sa rear deck? Yun space na gagamitin mo for the pair of 6x9 speaker enclosure would be roughly the same for a single 8inch subs.
audio set-up for beginners [continued]
