Page 101 of 154 FirstFirst ... 5191979899100101102103104105111151 ... LastLast
Results 2,001 to 2,020 of 3070
    #2001
    hindi ba advisable na gamitin yung bass boost/ bass EQ
    #2002
    Quote Originally Posted by aprilboyidol View Post
    depende sa listening preference mo sir. flat / zero settings(bass;treble sa HU, no preset EQ selected rin) lang ako dun sa dati kong setup. naka-negative 3 pa nga ako dun sa treble switch sa passive crossover ng component ko eh, tama lang para sa akin.
    Feb 2011
    #2003
    Quote Originally Posted by ParticleX View Post
    Are underseat subs good enough? My sealed sub is so large that it takes up a seat at the third row. I'm looking at the NBN-V12 generics at around 3-4k or so
    There are actually subs that can use up a smaller enclosure. One affordable brand is Hertz. Forgot the model, 10" siya, and it can run optimally using an enclosure that is as big as a 2-liter(?) box or kinda like 2 boxes of champagne/wine. Very capable and sounds impressive for a small enclosure.
    Feb 2011
    #2004
    Quote Originally Posted by mda View Post
    Can anyone recommend a decent set of 6.5" speakers under 10k for the FD Civic?
    Bumigay both yung stock front speakers ko and I might as well upgrade. If walang point in upgrading with everything else stock, should I just get the cheapest Pioneers or JBLs I can find nalang?
    Will be using the stock HU.
    Medyo harsh ang highs ng JBL/Infinity. Kinda piercing. Something warmer around that budget is a Hertz DSK or ESK. Or if you would like to add more, my favorite right now at that price is the Flux FS260. Very neutral sounding, easy to power, and adapts well in any kind of music.
    #2005
    Quote Originally Posted by sientobente View Post
    Thanks sir.
    I dropped by Mickey's last Wednesday since they were open and na talk ako into getting a Polk DB651 for 4500.
    Not sure how the reviews on this go pero mukhang may upgrade sa sound talaga.
    Di ko alam kung nakagat na ako ng upgrade bug haha nako
    #2006
    ok din naman ang polk audio sir.
    never mind about the reviews, it's your ears now telling it's better than your OEM kaya ok na iyan sir and enjoy
    now how about a sub for the next?
    #2007
    Quote Originally Posted by benchman View Post
    Need the rear space, and dapat medyo stealth. Hassle lang sa FD and almost all newer cars is that I'll need a dashboard kit for 2DIN.
    Ang mahal ng matinong 2DIN na may bluetooth! X_X
    #2008
    btw, your new speaker's sound quality should improve even more as you use it for a couple of days or a week. burn-in period.
    i was almost regret it the first time i heard how my new component speakers sounds. eto ba binayaran ko ng ganun presyo? parang wala lang talaga sya.
    but after a week of normal playing, yes it shines
    you may opt for a sealed box for the sub if you are after that space in the trunk. JL audio would be nice for the job
    #2009
    First thing I noticed was malinaw yung sound na lumalabas sa speakers kahit FM radio lang pnapakinggan ko.
    The stock speakers sound muddy. Saka nung hinahawakan ko yung pintuan from the outside, nag vvibrate haha.
    At this rate, no need for mine to burn in, ok na as is! hahahaha
    #2010
    that's great then. enjoy!
    #2011
    Question to all --
    Any decent store with a good selection of stuff in MM that is open on sundays?
    Most of yung kilalang installers are closed ata kasi.
    Stores like Blade/Concorde is the alternative kaso hindi super okay yung selection of items nila.
    Jul 2016
    #2012
    hello everyone! new forumer here.
    been in a hiatus when it comes to car audio set-up for a long time... and not updated anymore on the trends nowadays.
    what set-up would you recommend for below 10k budget, for the following:
    1. 2 front speakers to replace the stock speakers - what brand/model and how much?
    2. 4-ch amplifier to power the front speakers and subs - what brand/model and how much?
    3. re-use my old 10-inch RE sub in ported box.
    4. wirings and RCA - what brand/model and how much?
    5. good installer in the south (San Pedro-Binan-Sta. Rosa area)?
    to be installed in gen 2 cr-v, with pioneer deh-x2750ui HU. i'm using an i-pod touch and usb most of the time.
    would appreciate all inputs!
    TIA!
    #2013
    may negative effect po ba sa subwoofer kapag nakaset sa full pass setting sa amplifier .... salamat
    #2014
    wala naman, may maririnig ka lang boses/vocals sa sub which is hindi dapat.
    Feb 2011
    #2015
    Question to all --
    As far as I know, Maspro and JetCar in Banawe are open during Sundays. Di ko lang alam kung nagbago na sila. They are located on opposite sides of Banawe. Maspro in the old Banawe area, while Jetcar is the Mcdonald's side.
    Jul 2016
    #2016
    Quote Originally Posted by x.mayor View Post
    TIA!
    up ko lang po.
    Feb 2011
    #2017
    up ko lang po.
    Medyo mahirap si pagkasyahin sa budget, but if you are patient enough to do a step by step upgrade, given the existing gears you have, if I were you, i'd start with a good relaible amp like a 4ch- RF Prime. I think 10k fits the budget right there.
    Good installers around your area is Kid Audio/DB Audio. If you can travel to Paranaque, Musico will be one of the best and highly recommended installers around.
    Jul 2016
    #2018
    oh, I see. Thank you sir for the advice.
    For a casual enthusiast like me, do you think the RF R300X4 is enough or too much? I'm not into car audio competitions... just want a little punch. Would you recommend getting it online, like amazon? Saw one for 118.00 USD.
    Feb 2011
    #2019
    Yup sir, that is actually the exact model I am referring to. May member po tayo dito yan yung gamit sa isang kotse nya, si Ninjababez. Don't worry about the specs, RF is known to underrate it's numbers. Importante your existing sub would run on 4-ohms so you will be able to bridge 2-channels from the amp to power it. If everything is a go, great! Then ipon nalang for a good set of seps in the future.
    #2020
    Thanks sir. Will give those a try.
audio set-up for beginners [continued]
