Results 1,981 to 1,990 of 3070
June 24th, 2016 09:40 PM #1981
normal lang na nag-iinit ang mga amplifier, pero depende rin sir. gaano ba sya(amp)kainit at saan ang volume level while playing. cranking up the sound volume makes the amp way hotter than the usual which is most likely normal. and warm to touch lang dapat halos kung under low/normal listening/playing lang naman. there's something wrong kung umiinit yan nang halos mapapaso ka na while playing at low to mid sound volume.
- Mar 2009
- 71
June 25th, 2016 10:33 AM #1982
June 25th, 2016 03:00 PM #1983
- Mar 2009
- 71
June 25th, 2016 07:24 PM #1984
June 25th, 2016 09:26 PM #1985
^ more than enough na iyan kung true rated nga ang amp mo. but also note that an amp in bridge mode heats up more as compared with the usual/normal configuration. much more during "loud" playing.
curious lang ako how it sounds like with your amp gain at full. wala kang naririnig na distortion? you are about to kill your amp/speakers soon sir.
- Mar 2009
- 71
June 26th, 2016 11:47 AM #1986wala naman distortion parang wala pa nga bayo pero binawasan ko na yung gain sobra bilis kasi uminit kapag naka full try ko na lang kalikutin ulit baka maayos sana tama hinala ko na sa wire lang problema mukha kasi substandard nabile ko mabilis maputol mga fiber .... salamat sir sa mga sagot
June 26th, 2016 11:57 AM #1987
stop fiddling with your gain controls muna sir. pero ok na din at binawasan mo.
walang bayo? may built-in crossover/hi-pass/low-pass filter ang amp mo diba? naka-set ba to low pass filter ang channel 3&4 mo?
June 26th, 2016 12:08 PM #1988
- Mar 2013
- 6,160
June 27th, 2016 07:47 PM #1989Installed my 2nd android headunit in my other LC200. I replaced the pioneer 8750bt. Am super duper happy. Everything i wanted in a headunit is there. Waze, spotify, overlaid Lyrics via Musixmatch.
This Joying unit rocks. The sound is just as sweet and punchy as from the pioneer unit.
- Aug 2012
- 2,767
June 27th, 2016 08:46 PM #1990Wow bro, from Pioneer 8750BT to Joying. That is saying something. No noticeable difference in sound quality, tama ba?
Sent from my D5833 using Tapatalk
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
