Results 1,531 to 1,540 of 3070
- Jul 2012
- 33
February 6th, 2015 05:20 PM #1531mga gurus need your advise, may nakuha ako HU JVC KW-R910BT, kaya ba nito i-drive ang JBL GTO 629 consdering 3ohms siya even without an AMP?
checking JBL site wala yatang 4ohms na coax JBL speaker
- Feb 2011
- 62
February 6th, 2015 05:46 PM #1532I have adilemma regarding...
Initially ang choice ko is
JBL GT5 a604 (for focal 165as) and JBL-GTO601-1II (for GTO 1014 sub)
-both second hand
Ngayon iniisip ko palitan ng Firland audio class D
Firland Audio FX650/1 class D digital mono
Firland Audio FX300/4 class D digital 4chn.
-Eto naman both brand new.
san kaya ako mag benefit the most. HU pala would be 80prs !
February 6th, 2015 06:01 PM #1533
checking JBL site wala yatang 4ohms na coax JBL speaker[/QUOTE]
Yes, actually ideal ang 3ohms if head unit powered. Unfortunately, kakaunti lang ang mga car speakers that comes in 3ohms.
You can always add a external amplifier if you feel you still want to get louder.
- Oct 2006
- 43
February 7th, 2015 06:27 AM #1534advise needed (again)... i am buying a subwoofer, my amp is rated at 4x100wrms at 4ohm unbridged, 2x200wrms at 4ohm bridged.
setting up seps in front and subs at rear. if i buy a dual voice coil sub, can i connect each coil per each channel? or does the subwoofer need to be connected just to the bridged channel in the amp?
- Sep 2006
- 143
February 7th, 2015 11:48 PM #1535Question. I have the following equipment
Pioneer avh 8650bt
Focal access 165as
Focal ffp 4100 amp
Can I connect the tweeter into 2 Chanel's while the other 2 channels will drive the mid range. The amp has only a low pass and high pass filter.
Tnx
February 8th, 2015 04:49 AM #1536
Would the amp be able to set the crossover points for each channel? If not it is quite dangerous to do that. It might just damage your speakers. Better to have an external processor to do that for you. There are cheap ones like those from Firland and Lightning Lab that should work.
- Sep 2006
- 143
February 8th, 2015 05:47 PM #1537
February 8th, 2015 09:36 PM #1538
Sorry what do you mean oc mode? I'm also not sure a capacitor is something that will prevent the amp from frying your speaker drivers.
- Sep 2006
- 143
February 8th, 2015 09:44 PM #1539
- Jul 2012
- 33
February 9th, 2015 11:25 AM #1540*markgy salamat sa reply
ask ko na rin sana kung saan nakakabili ng stereo cable adaptor?
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
