Results 2,031 to 2,040 of 3070
- May 2010
- 138
July 20th, 2016 10:30 PM #2031
July 20th, 2016 10:40 PM #2032
Nice! Sakanila din ako nagpa deaden kaso di na nila binuksan yung inner metal door shell. Nagdagdag pa ko ng isa pang sheet per door pero DIY na lang. Nag dagdag pa ko sa may inner door shell, pinadaan ko na lang sa speaker hole.
Yung Custom box ko sir dun ko din pinagawa. Consumes 1/4th of the rear space. Bali 6 seater na lang SF ko which is ok lang naman ako masyado cargo and passengers. Naka quick disconnect plug din if ever i need the space.
July 26th, 2016 06:18 AM #2033
I agree with Boss Mark, it will definitely give an improvement. In my experience, it pushes out more details. This may mainly be caused by lower THD levels using an external amp rather than using the HU's internal amplification.
I think a Hertz combo works with that budget. It's the Hertz Deici 10" sub and Hertz HCP Amplifier if I'm not mistaken. Just add a little more for the enclosure and wiring.
- Mar 2009
- 71
July 30th, 2016 12:07 PM #2034mga sir kapag naglagay ako 1 pair ng 6x9 speaker yung nasa box sa trunk maririnig ba sa loob ng kotse yun o bale wala lang ayoko kasi maglagay ng subwoofer kailangan ko yung space .... salamat
- Mar 2013
- 6,160
July 30th, 2016 06:04 PM #2035I placed a focal IS 165 and PS 165 in my kia carnival using the amplification coming from the android headunit. Very satisfied with the sound. Much better than stock. I dont need a subwoofer. They put some sound deadening sheets and foam as well in the doors.
Wanted to go with the much cheaper pioneer separates but the store was able to sales talk me into getting the focals. I wonder if the sound is much different? Im not an audiophile so if i can save a lot of money, my next project will just go with pioneer or JBL speakers. Or is Focal really much better? Noob question sorry.
Sent from my SM-N920I using TapatalkLast edited by EQAddict; July 30th, 2016 at 06:15 PM.
July 31st, 2016 12:09 PM #2036
August 1st, 2016 04:39 PM #2037
My two cents over it is less exciting over the previous quotes of forumers
Malaki ba ang improvement? The answer will be..
No - if you don't play loudly. While there's an improvement because it's "cleaner" (usually referred to as THD%), I wouldn't pony up the moolah as an amplifier will cost as much as your speaker. A more cost-efficient method is to deaden your doors in order for it to rattle less and this gives you a better sound (rattles interfere with the sound frequency by cancelling certain sounds)
Yes - if you play loudly. Nothing better than good ol' power for playing them loudly.
It will depend. Maririnig ba? Well, if it plays full-range, it'll sound muffled (kinda obvious). If you're looking for the bass, the reason why subwoofers can be thrown to the trunk is because bass waves are long and have incredible penetrating power unlike high frequency sounds.
I actually have this theory that the reason why many people love Focal is because it's more expensive (there's the price bias) and because it's expensive it allows for a bigger magnet (hence higher sensitivity). Which means it'll be louder and cleaner than competing rivals.
Is the sound much different? It actually is. But is it really much better? I would say no to that.
- Apr 2016
- 3
August 2nd, 2016 12:43 PM #2038guys need help po. I'm setting up a simple sound system for my 1996 pajero. Binigay sa akin nung friend yung 3 months old niya na Kinetic KD5001 to start off. It has USB and aux-in pero no cd but its ok kasi more on usb naman ako. Ok kaya yung binigay sa akin na Kinetic HU? some say its taiwan pero good quality naman daw
August 2nd, 2016 01:35 PM #2039
August 2nd, 2016 04:31 PM #2040
For modern cars, the EPS seems to be more ubiquitous as the traditional engine-driven PSF...
A/c
