Page 73 of 154 FirstFirst ... 236369707172737475767783123 ... LastLast
Results 1,441 to 1,460 of 3070
    Dec 2014
    #1441
    [QUOTE=jhnkvn;2436655]*roblio
    Regarding the X12 mrv-1507 4channel 3600watts, please.. that's quite a generic V12 amplifier (bootlegs in fact of the famous Alpine V12) and it's usually used for powering of separates - not power-hungry subwoofers. Don't buy the 3600W, it does not even produce half of that value. It's doing something like 60W * 4 ohms on each channel.
    Isipin mo muna how you'll wire the subwoofer up. Since meron ka dalawang dual-VC subwoofers you have quite a lot of options naman. But to answer your question, kaya ba ng MRV ang 2-ohm load stable? The answer is... no. Most budget amplifiers aren't built that well sa power supply section nila to supply you 2-ohms on bridged mode. If you're doing a mono or 2-channel amplifier, baka pwede pa. But for 4-channels? Nah, they're just 4ohm stable bridged.
    Stable on 2-ohms? Probably on a per-channel basis yan. Ex. 60Wx4 * 4ohms, 90Wx4 * 2ohms. But please, don't believe the box. Yun 3600W palang nga linoloko ka na pano pa yun ibang specifications.
    Your best bet? Just use one of the voice coils - tutunong parin naman yan and use it on a bridged 4-channel amplifier.
    Thanks sa reply sir jhnkvn
    what ive done is that since dual 4ohms cya i make it series * 8ohms so ch1&2 bridge same as ch3&4 so i used up all the vc as series into the amp as bridge tama po ba safe po ba yung sub and amp ko?, also i used y splitter for the input. by the way sir jhnkvn i used it in the house lng i got power supply which has 42ampere adj voltage *13v. one more question can i power it up *14.4v or hangang ilang volts po kaya and safe cya?
    i really appreciate your advice sir jhnkvn
    Aug 2010
    #1442
    *roblio
    The problem with 8 ohms is that it isn't really inherently "safer", it just adds more resistance to the flow so you get less wattage at a given time. If a bridged amplifier is doing 150W * 4ohms, then at 8ohms, it'll be around half of that or 75W.
    For a subwoofer, you would want to lessen the resistance so you can tap more into your subwoofer's power. That's why people love wiring their subwoofers at 2 or 1 ohm.
    You won't be needing to use both voice coils just connect one of them and it'll play fine. Speaker-design wise, it'll change the characteristic of the sound since the subwoofer will have different T/S parameters than having 2 VCs wired up - but hindi naman sila nagkakalayo so it isn't a problem.
    If you're using a car amplifier wired up sa home power supply, you can push it to 14.4V without problems. Since most amplifiers are unregulated, you'll have more power to tap. For example, if you're 50W at 13V, you're doing something like 65W at 14.4V.
    Feb 2011
    #1443
    Happy New Year! Buhayin natin itong thread. Posting my car setups, SQ and SPL.
    4th-gen CRV
    [/url]
    Feb 2011
    #1444
    2nd-gen RAV4
    Sep 2011
    #1445
    ok kaya yung JBL GTO938? if I'd install 2 sa front doors tapos stock pa yung HU (ala pa budget), am I on the right track here, mga paps? TIA
    Feb 2011
    #1446
    Quote Originally Posted by chito2011 View Post
    I would suggest to go with Separates instead of a 6x9 sir.
    Dec 2014
    #1447
    Quote Originally Posted by sientobente View Post
    4th-gen CRV
    [/url]
    That CRV looks familiar. ;)
    Pa audi naman sir. Same tayo installer hehe
    Jun 2013
    #1448
    sir question lang po,
    ano po ba magandang 2DIN na head unit pang SQ?
    yung may bluetooth sana for handsfree calling ng android phone.. TIA
    Feb 2011
    #1449
    Quote Originally Posted by Chriswhiz View Post
    Sure thing Sir Ganda nga ng gawa ni Jonz.
    Feb 2011
    #1450
    *Erick Chavez
    I would still recommend Pioneer. Mainly because complicated yung cabling system ng Alpine. Get a Pioneer 2-DIN HU and then an external processor.
    Jun 2013
    #1451
    *Erick Chavez
    sir thanks sa reply, pioneer din nasa mind ko, parepareho lang ba ang sound quality ng mga pioneer head units, sa mga features lang ba sila nagkakaiba?
    saka another question pala po, sa pag canvass ko may mga pioneer may nakalagay na 2V yung preout, yung iba 4v.. ano po ba difference non mga sir?
    Jan 2012
    #1452
    How about lightning lab?
    Aug 2012
    #1453
    Quote Originally Posted by carwhacko View Post
    backread ka dito.
    http://tsikot.com/forums/car-audio-v...parates-95533/
    Feb 2011
    #1454
    Quote Originally Posted by Erick Chavez View Post
    In my own opinion, all Pioneer 2-DIN headunits sound the same. Mas makapal din tumunog ang Pioneer(except for P99) vs its Alpine counterparts.
    Regarding the preout voltage, maganda yung 4v because that means it has better current. It makes a difference on loud listening levels like SPL applications.
    Aug 2010
    #1455
    Even if you don't listen loudly, a higher pre-out voltage still benefits you. This means less gain in the amplifier which means a lower overall noise floor and that benefits you regardless on where your audio journey may take you.
    Feb 2011
    #1456
    I also remembered, having a high preout voltage also benefits a system with multiple amps, since it can deliver a higher voltage signal for each amp.
    Sep 2011
    #1457
    paps, what are separates speakers, eto ba yung component type? Thanks
    #1458
    hi sir,
    May I know, why do you recommend to go for Separates instead of 6x9? I went to a nearby shop, basically they quoted me the same price 4500 for either 6x9pioneer 3way speakers kor the front door or kicker separates (?). Target unit is navara, no approved budget to replace HU yet :-). Thanks.
    #1459
    Di ko alam kung tama ako. No need mag 6x9 kung may subwoofer naman na. Separates or component on front para nasa ear level ang high or tweeter. Ang mid and low kasi walang tutok. Paki correct na lang mga boss. Ahehehe
    Aug 2012
    #1460
    The gears that you would use depends on the over-all sound that you are after. Here are some sample configurations from Pioneer.
audio set-up for beginners [continued]
