Results 721 to 730 of 3070
- Jan 2013
- 139
October 8th, 2013 11:57 PM #721
- Apr 2005
- 132
October 9th, 2013 12:10 AM #722
October 9th, 2013 08:48 AM #723
- Apr 2010
- 742
October 14th, 2013 10:05 AM #724Ask ko lang where do I plug my tweeters? Sa amp ba or sa stereo?
Kasi I plugged in my seps directly sa stereo (bypassing the amp) for a while now... Then I tried plugging the seps kahapon to the amp and nagulat ako kasi mas naging klaro, although parang naging makalansing masyado, overpowering yung tweeters. Naka set naman sa 0 boost yung treble.
Thanks!
October 14th, 2013 11:07 AM #725
teka ginamit mo ba ang passive crossover ng seps? kasi iyan ang nagfi-filter ng frequencies na papasok sa midbass at tweeter. yung amplifier dapat naka-level match din sa head unit.
kung component speakers/separates, dapat kasi may passive crossover. so kahit saan mo sila ikabit pwede. kung sa amp, sa full mo ilagay (both hpf and lpf), either way frequencies will still be filtered by the passive crossover. (pa-correct nalang mga gurus kung mali ako)Last edited by ben_david19; October 14th, 2013 at 11:09 AM.
- Apr 2010
- 742
October 14th, 2013 11:24 AM #726Yes may passive xover. Medyo nadodrown kasi ang mids and lows, overpowering na yung highs, or di lang ako sanay
Set ang gains ng amp (0, +6, +12db) for treble and bass, naka 0 gain dun sa channels nung separates.
Am thinking na subukan ko ikabit ulit sa stereo yung tweeters (bypassing the amp). Kapagod kasi mag reinstall ng door panels
October 14th, 2013 04:05 PM #727
- Apr 2010
- 742
October 15th, 2013 10:41 PM #728
October 15th, 2013 11:39 PM #729
Hihingi lang po ako ng advice.
Stock po ang headunit and speakers on all four doors. May subwoofer ako na JBL with an amp na V12 ang tatak. Nagpaplano po kasi akong mag-upgrade ng speakers and headunit.
Ang nakikita ko ay yung DLS Reference RS6N. Kailangan ko pa po ba magdagdag ng amps? If so, anong wattage ng amp ang kailangan ko kaya? Sabi sa net eh Peak ng dls ay 160 per pair tapos RMS is 100 per pair.
Salamat po ng marami.
EDIT: may tweeters din nga po palang kasama yung DLS
October 16th, 2013 01:27 AM #730
Most passive crossovers have tweeter attenuation controls naman. You should check your settings doon.
If not, just balance it by increasing the output of the other regions (midrange, midbass) by increasing the midbass gain.
Ganun talaga mga tweeter, they're highly sensitive to power. Give them 2W of power, you'll be doing 93 decibels. On the otherhand, a midbass getting 2W of power will usually be doing just 80ish decibels.Last edited by jhnkvn; October 16th, 2013 at 01:29 AM.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
