Page 41 of 83 FirstFirst ... 3137383940414243444551 ... LastLast
Results 801 to 820 of 1645
    Jun 2006
    #801
    Thanks for the fast reply.
    #802
    Quote Originally Posted by KrisKros View Post
    I'm doing it. I have a DVC 12" Targa. 100x4rms Thunder audio powering the sub. I got it done at Jeff Tan's shop.
    tol magkano score mo kay jeff??
    ygpm
    May 2005
    #803
    question guys.
    my pioneer HU has only 1 pair of pre-out (?) for amp.
    now i have gotten hold of some seps and a 4ch amp.
    i'm planning to connect the seps and the stock 6x9 na kenwood speakers dun sa amp na 4ch. is this ok? or better if I let the HU power the seps and connect the 6x9 to the amp?
    May 2005
    #804
    Follow up question po.
    yung amp ko is the cheapo v12 na 800W 4CH.
    Am I better off not using it? and just connecting all the speakers (seps and 6X9) directly to the HU.
    HU ko is DEH-1750
    #805
    in my opinion, better to connect your speakers to the amp. To amplify the sounds. Plus, if your amp has crossover settings, you can play with that to get a custom sound to your taste of sound. I think it will sound better off of the amp.
    May 2005
    #806
    okie dokie! thanks!
    #807
    Quote Originally Posted by userfriendly View Post
    boss pede po ba na dalawa ang ibridge ko sa amp ko?? mtx4244 eto po spec. niya
    rms power measured at 12.5 volts Dc
    45x4 into 4ohm less than 1%thd
    60x4 into 2ohm less than 1% thd
    120x2 bridge into 4ohm less than 1% thd
    dynamic power measured at 14.4 volts dc
    55x4 into 4 ohm load
    100x4 into 2 ohm load
    200x2 bridge into 4ohm load
    Jun 2006
    #808
    Quote Originally Posted by ammad View Post
    Pwede. You actually answered your own question "120x2 bridge into 4ohm less than 1% thd" BTW, you have a unregulated amp. This means you get more power when your alternator is giving out 14.4 volts compared to 12 volts. That's the difference between your dynamic power and rms power.
    And as I said before, your amp is under rated meaning those power ratings are very conservative and the amp will pump out more than that.
    #809
    salamat po,, yun balak ko kasi channel 1 and 2 bridge sa seps. ko tapos 3 and 4 bridge sa sub ko,, btw 60rms po yun seps ko and yun sub ko 380rms ok na po ba yun set up na ganito??
    Jun 2006
    #810
    In this case no can do. When you bridge all four channels you turn your 4 channel amp into a 2 channel amp. When you bridge channel 1 and 2 you turn it into mono. So you can not connect your seps to it. If you do your amp will see a 2 ohm mono load and blow. For your seps connect your left to channel 1 and your right speaker to channel 2. Don't forget the crossover.
    You can bridge channel 3 and 4 and connect it to a single 4 ohm sub.
    Power rating wise, your amp and speakers are ok.
    #811
    ahh ganun po ba... yun seps ko kasi 4ohm yun eh 4ohm din yun sub ko,, bale ilan pong watts ang mabibigay ng amp ko sa sep ko?? maamplified na po ba yun seperate 2way ko at tweeters?? thanks po sa mga suggestions..
    Jun 2006
    #812
    Seps midrange and tweeter connected to passive crossover will get 55 watts.
    Sub will get 200 watts (bridged channel 3 and 4)
    #813
    hindi po ba bitin sa sub yun? o ok lang? dba po dapat match ang rms ng sub at amp?? ganun po pala yun pag 200wx2 ibig sabihin yun dalawang channel pag bridge 200w ang makukuha??
    #814
    sensya na po dami ko tanong hehe
    1.anu po ba pinagkaiba ng sub na 2ohm sa 4ohm?
    2.kung sakaling buy pa ko ng isa pang amp na 400rms para busog yun sub ko,, anong channel po ba sa sep ko ang ilalagay ko(mtx)?? yun 120wx2 bridge into 4ohm or yun 200wx2 bridge into 4ohm or hindi ito pwede sa dalawang ito salamat,,
    Jun 2006
    #815
    Ok lang 200 watts to your sony sub. Easy to drive ang sony subs. Try it 1st kung bitin ka then you can always add a bigger amp.
    1. Ohm is a measure of resistance. Lower number means less resistance. Most amps can only play into 2 ohms. A few high end competition amps can do up to 1/2 ohm loads but they are very expensive. Generally giving your amp a load that is lower than what it can accept is a good way to kill an amp.
    2. You said your seps are rated 60 watts. 120 watts will be too much for it. Might blow your tweeters. You can normally give a speaker more power than its rating but double is pushing it.
    #816
    ahhh thank you po,,bale yun channel 1 and 2 maproproduce niya 55watts? tapos yun channel 3 and 4 bridge 200wats,, nakita ko yun test result ng actual nakalagay sa 45x4 into 4ohm is 58w nung actual tapos yun 60x4 into 2ohm naging 88w!
    isa pa po hehe diba mas maganda po ang dvc sa svc? bakit po??
    Jun 2006
    #817
    Accrording to the test report you mentioned , channel 1 and 2 produces 58 watts each. So its actually 58x2 for your fronts. Perfect match for your 60 watt seps.
    Difference betwen dvc and svc is versalitity. You can use a dvc as svc or dvc and you have more wiring options. But if you are comparing the same model they should sound the same.
    #818
    boss bale yun 55x4 na dynamic power na lang yun papakabit ko noh?? tanong ulet kung sa sub ko lang kakabit yun amp ko pede po ba dalawang bridge sa sub ko? yun dalawang 200x2 bridge or ganto 120x2 bridge tapos 200x2 bridge?? pede ba to sa svc na sub ko??
    Jun 2006
    #819
    Pakabit mo lang seps. You will get the 55 watts. Wag mong sabihin sa installer na ikabit sa "dynamic power" tatawanan ka noon.
    In your case, marketing ploy ng mtx yung rms and dynamic power. Your amp has an unregulated power supply. This means that your amp will produce its rated power at 12 volts but give out more juice when fed 14.4 volts. If you noticed they rated rms at 12.5 volts this is the normal voltage of a car battery. They then claimed dynamic power at 14.4 volts. Your car will usually delvier 14.4 volts when it running. So more often than not, you will get 55 watts per speaker.
    It seems that you have your heart set on getting 400 watts to your sub. Just tell the installer to bridge channel 1 and 2 and connect it to one voice coil and bridge channel 3 and 4 and connect to the other voice coil. Your sub will see 400 watts. Note if you do this you need another amp for your seps.
    #820
    ahh pede pala yun dalawang 200x2 bridge sa svc kala ko hindi pwede,, para 400rms na haha,, siguro pag nagkabudget na lang ako saka ako buy amp para sa seps,, salamat po
    kunwari dalawa seps ko na tig 100rms 4ohm pede ba na dalawang 120x2 bridge into 4ohm ?
audio set-up for beginners (ARCHIVED)
