Quote Originally Posted by ammad View Post
ahhh thank you po,,bale yun channel 1 and 2 maproproduce niya 55watts? tapos yun channel 3 and 4 bridge 200wats,, nakita ko yun test result ng actual nakalagay sa 45x4 into 4ohm is 58w nung actual tapos yun 60x4 into 2ohm naging 88w!
isa pa po hehe diba mas maganda po ang dvc sa svc? bakit po??
Accrording to the test report you mentioned , channel 1 and 2 produces 58 watts each. So its actually 58x2 for your fronts. Perfect match for your 60 watt seps.
Difference betwen dvc and svc is versalitity. You can use a dvc as svc or dvc and you have more wiring options. But if you are comparing the same model they should sound the same.
