Page 36 of 165 FirstFirst ... 263233343536373839404686136 ... LastLast
Results 351 to 360 of 1645
    #351
    car is MB260e
    ok, separates for the front it is
    ok, coaxials for the rear I'll research on the size na lang. wala sa manual eh
    ok, i'll get a 4ch amp. I guess you're right, para future-proof na din.
    Re: subs, i'll have to talk my dad into it. Nanghihinayang kasi yun sa space ng trunk eh.
    Napansin ko sa mga set-ups, usually yung amp nakakabit sa front seps and yung iba walang rearfills. Is that really the suggested setup if SQ? I guess this doesn't apply if boomboom right?
    ah i see. So that means, kahit sa rear, ok lang separates. So this means may tweeters din diba? But isn't it that tweeters are for higher frequencies, and supposedly sa rearfills, lows dapat? Tama ba?
    Uy ilovedetailing thanks sa patience ha? Ako na lang yata ang tsikoteer na walang alam sa car audio setups eh. pero i'm getting there hehe.. thanks for your help!
  2. #352
    Box ain't that big, siguro oks na yung mga 1.2 Cu. Ft. thats around 14.5 x 14.5 x 14.5 inch. (estimate lang)
    Rearfills are there to complement the Subs, its not a requirement boom boom or not.
    Nope. If you put seps as rearfills you won't be able to use the tweets... since your staging is up front. Thats why you should use coax as rearfills.
    #353
    oh ok, now i get it sige thanks so much ilovedetailing! you were a lot of help!
    one budget setup.. coming up! hehe
    #354
    question lang mga peeps
    i bought a patrol meron na siyang keh 7450 HU. Di ko gusto ang tunog nya siguro pangit ang mga speakers anyways.
    any suggestion reasonable at descent sound system. Gusto ko sana Ill be able to play an mp3 or hook up my ipod.
    thanks
    Jan 2004
    #355
    Hooking up your iPod requires another gadget... Either a radio transmitter or possibly a tape deck insert.
    Personally I'd try to use my existing HU if it's still working and give decent output.
    Oct 2004
    #356
    Quote Originally Posted by the_wildthing
    install an rb10 or rb20 if your unit can be fitted with 1. you can now use your ipod through the aux. the radio transmitter or tape deck is prone to interference plus the sound quality is not that good.
    #357
    this i got from the mercedes benz club philippines..
    http://pub31.ezboard.com/bmbenthusia...ilippines19848
    bigsmooth:
    anybody with info if it would be possible for an iPod equipped with an iTrip radio transmitter to be used with an old Becker stereo (1971 model).
    Johan Limcangco
    The i-trip transmits the ipod audio via FM radio-waves. So just tune to a vacant FM frequency, program the i-pod to transmit at that frequency -- and there you go.
    w124_036
    Technically, the iTrip will work, as in may tunog. But masama yung tunog. Lakas ng static. If you really want to go with a wireless/fm modulation solution, get a Monster iCarPlay. works like the iTrip but (1) less static because mas malakas yata yung transmitter (I have one, may konting static pa rin but a LOT less than the iTrip) and (2) it comes with a lighter plug so it charges your iPod while you're listening to it. The downside? Mas mahal. Doble yata yung price.
    HTH!
  8. #358
    If you have the extra cash, sell your HU, upgrade to an HU with an iPod adapter for me this provides the best sound quality. Expensive tho.
    #359
    the car audio novice is back hehe!
    question, let's say I have a HU which has 2 pairs of pre-outs (front and rear), and i have a 4ch amplifier. I'll connect the front pre-out to 2 of the 4 channels in the amp. Is it ok to connect the rear pre-outs to the remaining 2 channels on the amp, then connect it to a subwoofer (bridged)? Or dapat sa sub-out lang talaga?
    Jan 2003
    #360
    akin na lang ang 7450 mo qman! Magkano? :D
audio set-up for beginners (ARCHIVED)
